HKS power predictions: 300+
Old Apr 7, 2003 | 02:36 AM
Gamera's Avatar
More speculation, but this is the first time I've seen a number quoted from an established tuner:
Old Apr 7, 2003 | 12:03 PM
evel333's Avatar
donna toki mo...
I really love that front end! It still conveys aerodynamic sleekness, adding a touch of subtle sharpness, without the aggressive bulk and gaping holes of the Mazdaspeed and C-West kits we've been seeing so much.
Old Apr 7, 2003 | 05:59 PM
Quick_lude's Avatar
Love to rev!
ARrrghghg.. Picnic bench alert! :D It would interesting if they can pull this off reliably..
Old Apr 7, 2003 | 06:23 PM
RX-Nut's Avatar
8 the HARD way.
wonder what the price would be to jack up a stock 6MT 8 with their 300+HP turbocharger...
Old Apr 7, 2003 | 07:06 PM
vipeRX7's Avatar
Junior Member
Car and Driver said at:
"But before you start mentally calculating how much more power a turbo version of the Renesis engine will punch out, we have to tell you that relatively cool exhaust gas from turbocharged rotary motors prevents efficient catalytic conversion, making it unlikely we'll see one soon, if ever."
So here's my question: why not put the turbo fans in the exhaust pipe AFTER the catalytic converter? That way emissions would still be low and you'd still get turbo power. Are there any problems with this layout?
Old Apr 7, 2003 | 11:27 PM
SPDFRK's Avatar
Car and Driver is talking no turbo from the factory. It will be very hard for Mazda to get the turbo renesis to pass emmisions standards. The idea of putting the turbines after the cats will not help the emmisions problem and will drastically effect the performance of the turbo, its not the turbo that cools the gases, the turbo unit itself gets very hot and the compression of air creates heat also, that is why you must cool the intake charge before it goes back into the engine. The amount of additional fuel and air your pushing through the motor to make horsepower keeps the motor from heating up quickly from start up and that is where the FI motor has an increased amount of unburned hydrocarbons. The faster an engine can get to full operating temperature the better for emmisions and if you have noticed the newer cars operate at a lot higher temp than ever before to help burn the fuel more completely. And as any hot rodder should know heat is the arch-nemesis to horsepower.
Old Apr 8, 2003 | 12:56 AM
wakeech's Avatar
mostly harmless
um, first, they're flat wrong: rotary emissions are higher tempurature and higher energy than any comparable piston engine.
second, there'd be no advantage to putting the cat before the turbine (which'd be impossible anyways, unless someone can create a 2" long CC): the problem with a turbo'd engine is that you get a TON of uncombusted HC's (that big *** backfire) when you lift off the throttle at really high boost... the AFM tells the computer a LOT more air is coming than what does, and you end up with a mega rich cycle, throwing it all out into the exhaust... that's mega HC emissions.
um... what??
the problem isn't that the motor takes longer to warm up (which it wouldn't/doesn't), it's that the cats take time to warm up no matter if it's FI or not: this was the achilles heel of all previous RX-7's, where they'd have a pre-cat which'd warm up really really fast (from those very hot exhaust gasses) so that it could help the always-high HC emissions while the main cat (which is better at doing that than the pre-cat) warmed up for a minute or two.
...not always. an engine will always operate best in a certain range, but yes, too hot is bad, but not hot enough bad too.
it'll be no harder than it was for an RX-7 to get through, and that one had perhipheral ports as opposed to the RENESIS's side ports: they could do it if they wanted, which they may not... the wider rotor'd motor is happening, like it or not.
Old Apr 8, 2003 | 02:34 AM
moogle's Avatar
rx-8 converted 2 evo.
that's some bitchin news. I'll be the first to order when they release the turbo.
Old Apr 8, 2003 | 08:52 AM
MrWigggles's Avatar
Two small points:
1. Emissions are much stricter now than 8 years ago.
2. I think everyone would like wider rotors. The reason forced induction is so widely talked about is we are all looking for extra power for the 1.3 liter engine in the RX-8 that many of us have already ordered. That's why this is the aftermarket section of the forum.
Agreed with everything else you had to say.
-Mr. Wigggles
Old Apr 9, 2003 | 12:19 AM
vipeRX7's Avatar
Junior Member
thanks SPDFRK and wakeech for clearing up my turbo question. My mistake was thinking that the turbo fan in the exhaust was what made the exhaust cool. I guess I can still look forward to aftermarket turboed RX-8s :D
Old Apr 9, 2003 | 03:00 AM
moogle's Avatar
Yup me 2. hearing my car goo vroooOOOmMM wooshhhh . Oh yeah can't wait.
Old Apr 10, 2003 | 03:46 PM
neit_jnf's Avatar
Just fyi, the WRX has a cat BEFORE and a cat AFTER the turbo...
Old Apr 10, 2003 | 03:55 PM
wakeech's Avatar
mostly harmless
... zoikes, that'd be interesting to learn about... i'd love to know why
Old Apr 10, 2003 | 06:57 PM
lefuton's Avatar
tyranosaurus rex-8
probably same reason the rx-7 had it. the precat (lil cat) took care of some hydrocarbons and had the advantage of really hot air, and the cat got much cooler air and handled the rest of the exhaust. (or something like that)
Old Apr 11, 2003 | 09:36 AM
evel333's Avatar
donna toki mo...
But both the 7's cats were after the turbos. I didn't know the WRX has one before the turbo. Is this true?
In the 7, while cold, the main cat is ineffective at catalyzing hydrocarbons properly. The pre cat was designed to heat up quickly and take care of emissions as the larger main cat warmed up. Once the main cat is operational, the pre cat is for the most part useless. This is why many owners can run a downpipe, yet still pass emissions.
Old Apr 11, 2003 | 12:37 PM
wakeech's Avatar
mostly harmless
... like i said... thx for the backup
Old Apr 11, 2003 | 02:34 PM
evel333's Avatar
donna toki mo...
(-_-) Whoops! My apologies for the redundancy. I should have read further up.
Old Apr 25, 2003 | 06:33 PM
rx7tt95's Avatar
NASA developed a new catalyst to work in the cold of outer space. Apparently automotive applications will show up on the market within a year. There's hope yet.
Besides cold emissions, the other turbo/rotary issue is back pressure. It kills rotaries plain and simple.
Turbines do cool the EGT of an engine. They're both exhaust and thermally driven. You'll see about 250 degrees of difference between EGT's just aft of the exhaust port and those say 4" behind the turbine on a rotary. After gasses exit the turbine they also expand and cool rapidly, slowing them down. By shrinking the exhaust after the turbo, you speed up velocity, but backpressure goes up. That's why turbo guys run huge exhaust systems.
RX-8 Racing
20
May 14, 2016 06:25 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
Trekk
12
Sep 25, 2015 03:08 PM
