Disappointment from Denver Auto Show
Old Mar 26, 2003 | 01:04 PM
BillK's Avatar
Unhappy Disappointment from Denver Auto Show
Last week's Denver Auto Show had an RX-8 on a roped-off rotating platform and I was able to talk the folks on hand into letting me sit in it.
First impression - Mazda's definitely building to a price point. The seats were of the strange perforated leather only found on Japanese cars like the S2000 - no biggie, though.
However, seated in the passenger seat (the driver's seat was power, which meant it couldn't be adjusted) I found the sad fact that even without the moonroof, I didn't fit.
Yep, hair was rubbing the roof. For reference I'm 6'1, long legs, long torso.
FWIW, I fit just fine in the Gen II RX-7, but not in the Gen III, and, unfortunately, not in the RX-8, either.
The trunk was, um, interesting, and is certainly roomier than that on say a Ford Mustang sedan but I wouldn't count on getting groceries with it unless you're talking cases of soda or beer.
The shifter felt taut and precise, but not as good as the one on an S2000, but then again since this was obviously a demo show car, who knows if it holds any semblance to reality in the first place and/or how badly it's been abused at this point.
All in all, though, it looked fantastic, and I can't wait to see one in the showroom and on the road, even if I won't be able to fit in one...
Old Mar 26, 2003 | 01:09 PM
RotaryXTypeSH's Avatar
come on man....
the seat wasn't adjustable that's y u cant fit inside the car.....
Old Mar 26, 2003 | 01:14 PM
BillK's Avatar
The driver's seat wasn't adjustable as it was power.
However, the passenger's seat was manual, and no amount of adjustments got my hair out of the roof...
Old Mar 26, 2003 | 01:18 PM
m477's Avatar
rotary courage
I'm 6'0" and I fit fine in an FD or an 8. Maybe you have really big hair. :p And unless you're buying food for 50 people, there's plenty of room for groceries, hell, I've even gone grocery shopping in my FD before with out too much trouble...
Old Mar 26, 2003 | 01:21 PM
what if you wash the gel out of your mohawk?:p :D
Old Mar 26, 2003 | 02:02 PM
babylou's Avatar
Re: Disappointment from Denver Auto Show
The perforations make the leather grip better, which is what is needed in a car that is manueverable. The little perfs also make the leather feel a bit softer.
I assume by "long legs, long torso" you mean they are longer than normal for a person that is 6'-1". I must then assume you have no neck to compensate for your torso and legs being out of proportion.
The trunk was, um, interesting, and is certainly roomier than that on say a Ford Mustang sedan but I wouldn't count on getting groceries with it unless you're talking cases of soda or beer..
I have no problem shopping with my Miata and the RX-8 trunk is about 50% larger.
Old Mar 26, 2003 | 02:30 PM
Lensman's Avatar
_________________
I thought the perforations are for the heated mode, to let the hot air through. Or am I deluded?
Old Mar 26, 2003 | 03:10 PM
AsianStyle's Avatar
I think the whole sitting thing depends alot on how a person sits in the car. If you sit straight or close to the steering wheel instead of reclining, obviously you will have less head room because your perpendicular to the roof instead of being at a angle, which will allow for more room.
Old Mar 26, 2003 | 03:44 PM
i thought the same thing
Old Mar 26, 2003 | 03:56 PM
RotorGeek's Avatar
Still spining
The demo I got into did not have perforations. It had ribbed leather. The seated were heated. My buddy that is 6.0 got in and did;nt have a problem.
Old Mar 26, 2003 | 04:12 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Perforated leather....
I have seen the perforations on other cars, and I think they are meant to allow a little air circulation on a hot day. The only car with a forced air type of seat heater is an 'S' class Merc, I believe. A nicer system, but a whole different kind of car, without the weight consideration of an '8'.
The heat on every other heated seat I have met is from loops of resistance wire just under the material.
Were I live, we know our seat heat!
Old Mar 26, 2003 | 04:16 PM
fishsauce's Avatar
from what m477 and RotorGeek said: Mazda makes RX's for people who are 6'0 and shorter. Why not try driving without shoes BillK?
Old Mar 26, 2003 | 04:22 PM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
that dude from Miami said he is like 6'0, drove it around for several days and didn't complained a bit about it.
Ask him if you are concerned about this.
Old Mar 26, 2003 | 04:34 PM
Superfan's Avatar
Member
Some questions: How big is your hair? Did you recline the seat some? Do you think that a qualified Mazda Barber can fix this issue? :>
Old Mar 26, 2003 | 05:58 PM
Sputnik's Avatar
Re: Re: Disappointment from Denver Auto Show
Originally posted by babylou
...I have no problem shopping with my Miata and the RX-8 trunk is about 50% larger...
Same here. You must be measuring a week's worth for a family too large to fit into the car to begin with (or you keep alot of junk in the trunk).
You are deluded. Perforations in the leather have nothing to do whatsoever with the fact that the seats are heated.
---jps
Old Mar 26, 2003 | 07:13 PM
feelthesweetbea's Avatar
perforated leather
Maybe the perforations are for air circulation, but think about this.... THe seats are cusioned right? i dont know how they are cusioned on the rx-8 but most cusioning has to do with sponges or sponge type material that have small chambers that hold AIR. when you sit the cusion squishes and becomes more dense, therefore air needs to go somewhere.... I bet the AIR GOES THROUGH the perforations... this would help in the longevity of the leather seat.
Old Mar 26, 2003 | 07:23 PM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
Just under 6'3" and no problem sitting in the RX-8. I will say however that when I first sat down it was too tight. I had to adjust the power seat to the lowest position -- but then no problem. I also sat in one with manual seats and it seemed to me that the power seats adjusted farther down and back.
The trunk was much larger than I expected :D
Old Mar 26, 2003 | 07:47 PM
gazita123's Avatar
Re: Perforated leather....
My friend's Saab also has the forced air heating for the seats. I think it is the 2001 9-3 or 9-5.
Old Mar 26, 2003 | 08:10 PM
bwayout's Avatar
... The trunk was, um, interesting, and is certainly roomier than that on say a Ford Mustang sedan but I wouldn't count on getting groceries with it unless you're talking cases of soda or beer.
I'm hope to be abe to sit in one at the Dallas Auto Show this weekend ... I hope, I hope!
Well, I've seen the 8 cubic feet in the G35 Coupe trunk (that includes a spare) so I'm prepared to see the trunk space on the RX-8, but I'm one one those who on the rare occasion needs to carry around alot of big stuff (like my big old 200 watt Fender Bandmaster Amp or my smaller in size advertising/art portfolio case - 30" X 42" X 6")... I'm not sure if I'm going to be pleased or not.
I just can't wait to see it in person!
Old Mar 26, 2003 | 08:47 PM
khoney's Avatar
FX8TED on my RX-8
Phew! I was getting worried - I'm 6'3" myself. In my 2nd gen 7, I drive with the seat all the way back and the seatback partially reclined. I guess I'm expecting to have to do the same in the 8.
Old Mar 26, 2003 | 10:11 PM
RotorGeek's Avatar
Still spining
Here is a pic of the trunk with some real life use. i was surprised by its size
Old Mar 26, 2003 | 10:58 PM
IGOZMZM's Avatar
Zoom Zoom Member
I've got to say it, but don't you people understand that the perforations are to help reduce weight :D :D
Old Mar 27, 2003 | 12:04 AM
BillK's Avatar
I rarely shop for groceries more often than once every three weeks or so, so I always have about eight or nine bags - enough said there.
OtoH, a Miata? I really don't fit in a Miata; I look over the windshield in one.
And yes, it may be my seating position; I don't drive in the "lowrider" reclined position, but rather with the back rather close to a 90 degree angle to the seat bottom (i.e. if the seat back is spring loaded with detents usually only one click back...)
As I said before, I can't wait to actually see a real one rather than the demo that's gone from auto show to auto show...
Old Mar 27, 2003 | 12:39 AM
MrWigggles's Avatar
Bill,
If you were in the passenger seat, how did you know that, "The shifter felt taut and precise, but not as good as the one on an S2000"?
-Mr. Wigggles
Old Mar 27, 2003 | 08:09 AM
BillK's Avatar
Since the power driver's seat was set in one position, I was able to, albeit uncomfortably, wedge myself into the driver's seat to get a general feel for shifter feel, instrument and gauge placement, etc.
However, to move the seat forward and back to judge fit, one had to use the manual passenger seat...
