could u guys post some nice aftermarket rims for RX8
Old Mar 22, 2003 | 03:19 AM
RotaryXTypeSH's Avatar
would someone post some pix of RX8 with nice looking rims
Old Mar 22, 2003 | 03:30 AM
Beemer's Avatar
Technical prodigy
I like these wheels for my RX-8:
ENKEI AEGIS
VEILSIDE ANDREW BACCARAT
I don't have a picture of them on an RX-8 so I hope someone will photoshop these under a titanium grey one
Old Mar 22, 2003 | 12:05 PM
Mazda man's Avatar
Endangered Species
I like these wheels:
Momo Twin
Old Mar 22, 2003 | 05:35 PM
hmm...
i was thinking about a rim that couldn't be seen easily...i dont want a rim that could be seen everywhere....but thos are great posts guys!!
Old Mar 22, 2003 | 07:14 PM
Ruler_Mark's Avatar
i like the mazda speed rims but if i go after market i like the TSW Pin System.
Old Mar 23, 2003 | 01:29 AM
RX-Nut's Avatar
8 the HARD way.
here we go.. nice pimps..
NOT!
Old Mar 23, 2003 | 08:53 AM
tpryor's Avatar
Nice Wheels
Autocross Wheels:
SSR Competitions
Old Mar 23, 2003 | 08:55 AM
tpryor's Avatar
Street Wheels:
Fikse Mach 5
Old Mar 23, 2003 | 11:46 AM
wakeech's Avatar
mostly harmless
...i don't know why, but i've always been partial to the Fondmetal look
Fondmetal 6600... dammit, i need a pic...
anyhoo, another great wheelmaker, BBS:
the BBS RX (fitting name, no??)
woooow... she's boooootiful...
Old Mar 24, 2003 | 08:31 PM
MrWigggles's Avatar
ENKEI AEGIS
Funny you should mention it. I have these wheels for my sc300 and I have ordered a titanium RX-8
I love the way these wheels look but being a owner I can tell you not everything is perfect with them. They have the following issues:
1. The inner "hub" of this three piece wheel is chromed well, but the outer "barrell" section has a very cheap chrome plate to it. I was dumb enough to use chrome wheel cleaner on these "chrome wheels" . Well, it screwed up the coating on the barrell section pretty bad. But even if I hadn't used the cleaner, I don't think the coating lasts that long anyway with it being especially sensitive to dirt, grime, road salts etc.
2. The wheel has a right angle valve stem and that has contributed to three seperate flat tire incidents. If the right angle stem isn't put on just right (I thought it was on the rim coming from factory but it is actually installed at the time of tire mounting) with the correct amount of torque, it will overtime vibrate itself loose and a small leak will be formed. This means you'll have to go to a top notch wheel shop to get the tires/wheels mounted AND you'll need to monitor pressure constantly. I guess it is the smooth ride of my SC300 but low tires in the rear of the car are very hard to sense just by driving. And these wheels aren't good about taking punishment when the tire is low. Which leads to ...
3. The barrell of the wheel isn't very strong. I have, on one occassion, felt my tire being low and have pulled over before it went completely flat. "Pheeww!", I thought to myself, but the wheel had already been dented badly in the short period that the tire was low even though I don't remeber hitting any bumps.
4. Despite the wheel being a three piece wheel, Enkei won't replace just the "barrell" of the wheel. You have to buy a whole new wheel if the wheel is not fixable. (one of my flat tire incidents led to a non-fixable wheel).
5. Despite the wheel being currently listed on Enkei's website, some sizes have been discontinued. If you need a new wheel in a particular size that they don't make anymore, you're SOL.
The good news is that the bolt pattern will match the RX-8's. I will be putting them on to see how well they fit. If I can get my 18X9.5's to fit on the rear, you'll be looking at one happy man.
But personally, I would find another wheel to go with.
-Mr. Wigggles
Old Mar 25, 2003 | 09:20 AM
WEAPON X's Avatar
Yeah those Enkeis are Hot I've seen em on alot of old z's
Old Mar 25, 2003 | 09:27 AM
Beemer's Avatar
Technical prodigy
That doesn't sound really good for those Enkeï's, does anyone know something about the quality of Veilside rims?
Old May 6, 2003 | 12:13 AM
Efini 8's Avatar
no pistons!
I say Volk TE-37 in titanium silver :woot:
Old May 6, 2003 | 10:42 PM
Superfan's Avatar
Member
Does anyone know what the size is on the Mazdaspeed rims. They might just look bigger since the car is lowered. I really like those MS rims and want to get a set similar to them so if anyone knows who makes them for MS or a rim that is similar in style please let me know. I ordered the 8 in black and I've always liked black cars with gun metal rims.
Old May 7, 2003 | 05:59 AM
babylou's Avatar
Mazdaspeed rimes are 18"x8". Same as factory sport package. The Mazdaspeed rims can be had in aluminum or magnesium (very light, mass and wallet). Magnesium does not hold up well to road salts and is not as pot hole tolerant as aluminum.
Old May 7, 2003 | 05:12 PM
MrWigggles's Avatar
The factory offset is reported to be 50mm while the Mazdaspeed rims have an offset of 40mm.
That is one reason why they look farther out than factory. 10mm is almost half an inch.
With that in mind you should be able to get 9" rims with 50mm offsets on the car. My Aegis rims on my current car are 9.5" @ 45mm and 8.5" @ 44mm. When my RX-8 arrives, I will give them a shot and see if they fit.
I am positive the 8.5" won't have a problem on the front or rear but the 9.5" (with 275 rubber) are going to be a tight squeeze on the rear and have almost zero chance of fitting on the front (I would never want them up there anyway)
-Mr. Wigggles
Old May 7, 2003 | 06:25 PM
neofreak's Avatar
Mazdaspeed wheels have been traditionally made by Volk, if you browse their website, you'll see the previous mazdaspeed rims listed there. (MS-01, MS-02).
I vote for any wheels made by Volk, SSR, Advan, Fiske, HRE, etc.. Eneki has been pretty ricey lately, and most of the other brands are low quality knockoffs.. adr, tenzo-r, motegi, etc.
Old May 7, 2003 | 10:19 PM
Superfan's Avatar
Member
I like the Volk TE37, Gram Lights 57Pro and the Mazdaspeed Rims. I think I’m just going to wait until I have the car to get the rims. I’ll kick my self if I buy them now and a couple of months down the road the MS rims become readily available.
Old May 28, 2003 | 12:27 AM
Efini 8's Avatar
no pistons!
HRE Wheels 547R Multi Piece, custom forged in silver/gunmetal color paint
Racing Hart M5 - 3 Piece Version in silver
Old May 28, 2003 | 12:34 AM
Hercules's Avatar
God I hate 'slammed' vehicles.
Rims are decent though.
Old May 28, 2003 | 03:48 PM
takahashi's Avatar
It is so sad
You bloody American... get rid of the chrome wheels please.
Get some style. Even the rice cars look better than yours
That comments is to you Efini
Old May 28, 2003 | 09:56 PM
Efini 8's Avatar
no pistons!
Re: It is so sad
dude are u blind? those arent chrome wheels. they are forged aluminum. The Racing Hart wheels are made in Japan... so I do not know what you are talking about. obviously your english really sucks cuz I did not say they were CHROME nor did I say it was MY car.
Old May 29, 2003 | 03:59 AM
MrWigggles's Avatar
Efini,
Your silver rims are too shinny. Use photoshop and put some dirt on them to make the Aussi happy.
Make the wheels look like they came out of a Mad Max movie.
-Mr. Wigggles
Old May 29, 2003 | 10:41 AM
dreamgetter1's Avatar
that's what happens when you live on an island, you have no concept of reality?! LOL LOL:D
I'll take a set of the HRE'S please.
Old May 29, 2003 | 12:58 PM
Aeterna's Avatar
Cool How about...?
How about something like these?
I like the look of HyperSilver and Hyperblack, though normally I'm not a black-rim person. The good thing about the even symmetry is that they have no 'roll-dig' look to them.
What I mean by that is, when rims have curved or angled spokes in one direction, when they are mounted on the car, one side will look as if the wheels are 'rolling', the spokes smoothly caressing the ground, while the other side of the car will have wheels that appear to be 'digging' with clawlike ferocity into the asphalt of the street.
Now, if you have a preference for either, that's a personal taste, but I think the uniformity is most aesthetically pleasing, either all of one OR the other.
