Order Pass-Through Replacement?
Old Jul 13, 2004 | 11:40 AM
truemagellen's Avatar
Attracts tree branches
Question Order Pass-Through Replacement?
I am looking to have subs installed in my pass through panel and it will be designed so that I can remove the whole setup when I need to use the pass-through (skis, etc).
Is it possible to order a replacement of the identical mazda pass-through panel (a true mazda part, not an aftermarket pass-through, not that one exists anyway)?
Reason: When I have to travel to a certain crime ridden city...I want to be able to remove the modified for sub panel and have the orignal mazda part so that I reduce my chances of a smash and grab of the subs.
Old Jul 13, 2004 | 04:26 PM
I called mazda north america about this one...and they were CLUELESS!
Old Jul 14, 2004 | 02:22 PM
Sputnik's Avatar
Yes, you should be able to order that part. You will probably have to go down to your local Mazda parts department equipped dealership (not all dealerships have full parts departments), have them look the part up, and you will probably have to have them special order it for you, and it will probably take some time to get in. Since it is not an item that normally needs replacing, I doubt that even regional warehouses will have them. Most parts departments require you to pay for your item up front if it is a special order piece.
Sometimes, you will have to have some patience while the counter person figures out which page to find the exploding diagram, so that the right part can be identified. But you should be able to get any piece of that car from Mazda.
---jps
Old Jul 16, 2004 | 12:52 AM
Omicron's Avatar
Check with Tommy at Rosenthal Mazda. He'll get it for ya, no problems.
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
rotorocks
47
May 11, 2016 03:23 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
t.swain
Aug 10, 2015 06:55 PM
