Xbox in car?
Old Jul 7, 2004 | 09:54 AM
freakshow's Avatar
Lightbulb Xbox in car?
well i want to put a xbox in my car... but is the audio output going to come through my main speakers? I have the avelectr. switch on order.. just wondering w/ my xbox with all the music i have saved on it.. could i use it as a sort of cd player... can someone who has a xbox in car anwser my questions..??? Thx..
Old Jul 7, 2004 | 11:44 PM
AWillsea's Avatar
Gadget Guru
The avelectronics setup includes a hard wired FM modulator to play sound out of any of the input devices (including the xbox). You can use your xbox just as you are planning. The only issue will be where to mount the xbox.
I have a pS2 mounted in the cargo tray in the trunk hooked up to my avelectronics and the rear facing camera license plate frame hooked up to it as well. Works great!
Also have pentium based carputer with lilliput 7" touchscreen for playing DVDs, MP3s, onboard car diagnostics and dynometer using autoenginuity's OBDII/CAN adapter.
Old Jul 8, 2004 | 09:49 AM
freakshow's Avatar
Exclamation How hard to hook it all up?
How hyard is it to hook avelectronic switch up... i know it only says 4 wires to cut but how much of the console do i have to take off.. does the av kit have instructions on how to install in the rx8? Can u help me willsea
Old Jul 8, 2004 | 11:09 PM
Mazda3ndp's Avatar
check out this post.
https://www.rx8club.com/showthread.p...threadid=31108
Old Jul 9, 2004 | 08:35 PM
AWillsea's Avatar
Gadget Guru
Not hard at all. The centre console comes out in about 5 minutes, the radio comes out in about 5 minutes. The Unit gets wired up from the trunk/back of the back seats. The wires you need to tap into are directly under the center "door" between the back seats. You only need to remove the radio to plug in the FM Modulator for sound. It plugs in between the car's antenna and the radio (No wires to cut there)
Skyl3r
Dec 2, 2019 04:51 PM
akagc
Aug 11, 2015 07:07 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
