MS ground wires
Old Jun 10, 2004 | 12:59 AM
IZoomZoomI's Avatar
Boost needed
MS ground wires
Found a lot of MS groundwires for sale on ebay, just wondering if those were legit or not. any input ? thx
Old Jun 10, 2004 | 05:48 PM
cortc's Avatar
They are not, I installed the original ones from JDM Mazda; the ones that come on the Mazdaspeed RX8... The ones on Ebay are not the same...
Old Jun 10, 2004 | 06:40 PM
PUR NRG's Avatar
My input would be they have a negligible effect if any. Installed a clone set for $50 and didn't notice a difference.
________
LovelyWendie
Old Jun 10, 2004 | 11:44 PM
Japan8's Avatar
Int'l Man of Mystery
I think there is another thread where Canzoomer was talking about this.
PUR NRG... likely you saw no improvements BECAUSE you used a clone set. What that thread was saying is that you can't use just any old heavy guage wire. YOu need the high quality stuff like pro installers used on their audio systems.... the stuff made up of thousands of thin copper wires.
That being said... no one has really seen a performance increase. A difference in the charging system (i.e. lights and radio running , etc.) has been noted though.
Old Jun 11, 2004 | 12:11 AM
bureau13's Avatar
You don't need "audio quality" stranded wire for a grounding kit! Actually, I'm sure those "clone" sets are stranded too...it would be next to impossible to use if it were not. Seriously though, the electrical impact of stranded vs. solid-core wire is real...but not for an application like this, and frankly, not really for audio either, I don't care what the audio snobs tell you :-)
jds
Old Jun 11, 2004 | 03:37 PM
cortc's Avatar
It helps stabilize the electrical system; it can affect everything from the idle quality to audio system interference... It works and I have noticed a slight improvement in idle... I would like to note that I have driven several RX8s not just mine since I have access to everyone on our dealership lot, and since I installed the wires my car has the smoothest idle of any other I have driven...
Old Jun 11, 2004 | 04:48 PM
PUR NRG's Avatar
After install I wanted to notice a difference--especially in idle--but didn't see/feel anything. It was a 4 AWG stranded copper cable with crimped connectors using the same mounting points as MazdaSpeed's. Personally I thought the cable was total overkill and would have preferred 8 AWG for better flexibility and neatness.
________
LM001
Old Jun 11, 2004 | 07:26 PM
Magic8's Avatar
Mazda Mole
I got mine from someone on ebay. It was $50. Real high quality stuff with thick braided copper wires, nicely crimped connectors, and clearly written instructions. Real professional job.
Looks really cool but the performance....uhmmm.....did I mention it looks cool.
Old Jun 12, 2004 | 10:20 AM
cortc's Avatar
Buy the original, there is a reason Mazda put it on the Mazdaspeed cars...
Old Jun 12, 2004 | 08:57 PM
IZoomZoomI's Avatar
Boost needed
yea the i've decided to go with the orginal but is canzoomer the only vendor for the wires ?
Old Jun 12, 2004 | 09:29 PM
Japan8's Avatar
jds
Don't shoot the messenger. As I said, I believed it had been said by canzoomer in a thread in his forum...
Old Jun 12, 2004 | 10:39 PM
bureau13's Avatar
I also remember CZ posting the exact dimensions of the kit for those who wanted to roll their own. Certainly a crappily-constructed grounding kit has the potential to do more harm than good...it just doesn't need anything all that special in terms of wiring.
Another thing about these grounding kits...all they're ever going to do is give you back something you're losing due to an inadequate stock ground system. IS the stock system inadequate? I have no idea...I would hope not! However I know in the FD world, a much larger percentage of people adding grounding kits were claiming obvious improvements. Of course, the fact that those cars are 10 years old or so may have something to do with that!
jds
Old Jun 12, 2004 | 10:45 PM
Japan8's Avatar
Well for all the good that is the FD... it does have its inadequacies... apparantly cooling is one of them and grounding too it seems.
Old Jun 13, 2004 | 05:56 AM
rx8spiritR's Avatar
----Got Rice?----
so you all perfer the MS earth/ground wire and not those cheap **** from ebay.
Old Jun 13, 2004 | 09:11 AM
Magic8's Avatar
Mazda Mole
I prefer the cheaper stuff from ebay. I really don't think it's sh*t. The guy I bought it from put together a professional kit.
to me a copper wire is a copper wire. What other differences can there be between the MS kit and a imitation other than brand name? CZ even said you can make a kit similar to the MS stuff by yourself.
BTW I know this has been discussed before, may want to do a search.....
Old Jun 13, 2004 | 10:25 AM
policyvote's Avatar
Something nobody else is mentioning--using good grounding points makes a big difference as well. You want unpainted frame, as far away from the battery, engine block, and other grounding points as possible . . .
Peace
policy
Old Jun 14, 2004 | 01:32 AM
rx8spiritR's Avatar
----Got Rice?----
this is where it takes me in my search
Old Jun 15, 2004 | 12:34 AM
IZoomZoomI's Avatar
Boost needed
contacted rotaryextreme, apparently the ground wires are discontinued.
Old Jun 15, 2004 | 12:36 AM
Japan8's Avatar
Many other companies offer them as well. Revolution, RMagic, Auto Exe... to name a few...
Old Jun 15, 2004 | 12:32 PM
Shooter's Avatar
I used the schematic CZ posted and made my own grounding kit out of 8 gauge wire. TOok about 2 hours after soldering and cutting but it was not big deal. Cost me $20.
Old Jun 21, 2004 | 11:02 PM
kellybrf's Avatar
so i take it these arent actually ms?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33574
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
