Mazdaspeed Air & Oil Filter
Old Jun 6, 2004 | 09:43 PM
cortc's Avatar
Smile Mazdaspeed Air & Oil Filter
Just received this, will install on Monday... Oil filter at next change also...
cortc's Avatar
Pic 2...
Another...
Old Jun 6, 2004 | 09:45 PM
cortc's Avatar
Pic 3...
Can anyone read Japanese?
Old Jun 6, 2004 | 10:14 PM
ranger4277's Avatar
Cones need lovin' too!
Now I KNOW you have too much money to spend.
Old Jun 6, 2004 | 10:17 PM
neit_jnf's Avatar
Is it reusable or one time use?
Old Jun 6, 2004 | 10:22 PM
cortc's Avatar
One time, but it is very clean around here so it should be good for about 20K miles...
Old Jun 6, 2004 | 11:02 PM
takahashi's Avatar
Where does it go... to the airbox or in front of the glove box...?
Old Jun 7, 2004 | 01:49 PM
cortc's Avatar
Airbox...
Old Jun 7, 2004 | 02:46 PM
-8-'s Avatar
-8-
does it show any HP gains?
RX82004's Avatar
Where did you get it? I want one.
Old Jun 7, 2004 | 02:49 PM
cortc's Avatar
Had Canzoomer order it for me from Japan, it is like the other high flow drop-in filters; good for 2-5hp...
Old Jun 7, 2004 | 04:32 PM
Japan8's Avatar
Int'l Man of Mystery
Re: Pic 3...
Why? What do you need?
If you get me a good pic of it, I can give it a once over and tell you if there is anything to worry about or special instructions.
If you want a full translation... weeell. I prefer to avoid doing that as it is both time consuming and tends to leave you pretty wiped at the end.
Old Jun 7, 2004 | 04:36 PM
cortc's Avatar
Japan8: No, no translation needed, just messing around? But if I ever do I know where to go thanks...
Old Jun 7, 2004 | 04:48 PM
Japan8's Avatar
My new parts mag mentions it... 10% increase in airflow for better throttle response.
The Auto Exe drop-in offers 20% increase in airflow...
Old Jun 7, 2004 | 05:14 PM
cortc's Avatar
Yes and the other guys like green/knn say 7-10hp, but they are oil filters and I am not a big fan... I am going all Mazdaspeed...
Old Jun 7, 2004 | 05:15 PM
cortc's Avatar
You know, getting the filter in and out on the RX8 is a pain...
Old Jun 7, 2004 | 05:16 PM
Japan8's Avatar
I don't think Auto Exe's is an oil... it is made of the same materials as the Mazdaspeed (and is a hair less expensive).
With the setup you are aiming for, better off to get the MS filter and keep with the MS kit parts.
Old Jun 7, 2004 | 05:31 PM
cortc's Avatar
Oh, then the Auto Exe is cool... It's going to be all Mazdaspeed, unless they don't come out with a supercharger than it will be all Mazdaspeed + ?
Old Jun 11, 2004 | 03:24 PM
cortc's Avatar
Installed, it is a little louder and throttle response is better... I would say 2-5hp...
Old Jun 11, 2004 | 04:34 PM
DreRX8's Avatar
I installed the K&N Drop in and I noticed slightly louder-and quicker response--however; is the Mazdaspeed air filter paper? Because if it is I don't see how it differs from the stock paper air filter that is slightly restrictive, save for the Mazdaspeed emblazoned on the side. The Green Filters and K&N use a proven higher flow element.
Old Jun 11, 2004 | 05:18 PM
cortc's Avatar
I have used K&N filters in the past and don't like them... Oil filters all shed some oil that eventually coats the inside of the intake tract and MAF sensor and degrades performance... Oil filters are old tech that was designed in the days of carbureted race engines and is not a good choice for fuel injected cars... (Of course if you are K&N you may say otherwise…) A well designed paper element with a larger surface area will flow better than stock and provide a performance increase that is consistent without contaminating the intake tract beyond the filter...
This is why OEMs do not use OIL impregnated filters, nor do I...
Old Jun 15, 2004 | 01:28 AM
IZoomZoomI's Avatar
Boost needed
hrm i wish you had access to a dyno, so every mod you do would let us know if its seriously worth the investment.
Old Jun 15, 2004 | 01:35 AM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
cortc is building his very own Mazdaspeed RX-8 here in the states part by part :P If he went for the Mag Mazdaspeed rims then it would have been even more bling bling than it is already.
Old Jun 15, 2004 | 07:25 AM
DreRX8's Avatar
I thought that we are talking about air filters cortc? I don't use K&N oil filter, but I endorse their air filter elements. The mazdaspeed one looks to be paper and that is less efficient for air flow--it looks just like the stock one from the pics.
Old Jun 15, 2004 | 07:39 AM
cortc's Avatar
Much more surface area, deaper and more open pleats...
