Front and rear rotor trim ?
Old Jun 3, 2004 | 09:58 AM
dinbougre's Avatar
Hello, i want to put the 2 rotor trim in front and rear of the car. How do you install it? just stick it or how?
My french customer told me i can put only on the front rotor trim, because rear is not the same, right or false? because i saw on this forum lot of RX8 with front and rear rotor trim.
How much is it in US for one of this ? Here is about 100€ too expensive
Old Jun 3, 2004 | 10:37 AM
robertdot's Avatar
I'm pretty sure the front and rear accents are different pieces. So, you'd have to buy one of each. If you have the euro rear fog light, you can't install the rotary accent w/o modiying the accent alot, and then it will look awkward.
Apparently, the accent sticks on.
Many people buy them from Trussville Mazda. Check prices there.
Old Jun 3, 2004 | 10:38 AM
derwankel's Avatar
Here is a link to the "Do-It-Yourself"
https://www.rx8club.com/showthread.p...threadid=27912
You may not be able to install the rear accent, as I believe you folks have the rear fog light and there is an issue with fitting both items in that rear panel
Hope this helps!
Pricing here in the States is about $120.00 for the pair, so comparable to your 100 Euros ... indeed expensive.
Old Jun 4, 2004 | 01:57 AM
dinbougre's Avatar
ok, i didn't know that rear fog is only in europe, i tought all of you had remove it :D
thanks for the 2 links i'm going to check the prices, thanks
Old Jun 4, 2004 | 01:58 AM
dinbougre's Avatar
Hope this helps!
no in france you don't have the pair for 100€, only for the front rotor not rear
Old Jun 4, 2004 | 02:13 AM
dinbougre's Avatar
i'm maybe a little bit stupid but i didn' found the front accent on trussville website
can someone confirm it?
Old Jun 4, 2004 | 08:54 AM
robertdot's Avatar
It's there. I'd give you a direct link, but the way the site works you can't. Damnable posted data.
Anyway, front accent is $52.33 USD (~ 42.7930 Euros), and the rear is $63.25 USD (~ 51.7276 Euros).
Just do in the drop down boxes Rx-8 > 2004 > Accessories Exterior, and search for Part #s F151-V4-350F and F151-V4-030F (listed as Polished Front Rotary Accent and Polished Rear Rotary Accent). They are a little over 1/2 down the page.
Billy Marcial
Mar 1, 2018 06:50 AM
jlm2664
SE For Sale/Wanted
Mar 9, 2016 11:50 AM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
AussieGray
Jul 16, 2015 03:58 AM
