Pics of Front door Speaker install replacing stock bose speakers
Old May 31, 2004 | 04:24 PM
16psibrick's Avatar
got bored sitting at home today so I decided to get the speaker install done on my bud's rx8, since tint is going on thursday, i figure I should do this before then...
anyway, things went pretty smoothly considering i have never worked on this car before. the front speakres is a set of crystal csx 615 6.5" component coaxials wth bridge mount tweeter and stand alone crossover...crystal being among my fav. brands and the main brand we carry.
anyway, here goes:
the door panel went off with out a hitch thanks to the mechanics repair manual i have of the car, i must say, the stock bose speaker is one of hte strangest I have ever seen...9" speakers with reverse mounted cone? or is i passive radiator?> anyway, for anyone who is interested in really good sound quality, i think a set of morel 8" integra coaxials would be a perfect fit for these doors anyway, back to the isntall...
i first took off the stock speaker and used the moutline to cut a mounting baffle out of 1/2" mdf, with a countersunk cutout to sink the crystal speaker in. I used the stock screw holes to install this baffle. this is followed by a good layering of dampening to prvent rattles.
After looking at the stock wiring pass through, i decided that it was way more trouble than its worth and I was going to drill my own holes. on teh doors side, i was able to pop out a small grommit near the speaker. i inserted a plastic grommit there. next, I drilled out a comparable hole on the car side of sheet metal (its double walled) and isntalled another plastic grommit. finally, on the inside kick panel sheet metal, i drilled a third hole to pass the wires into the car, of course, a grommit was also used. then, speaker wire for the speaker was run through, covered with one heat drunk tubing and then electrical tape. the speaker was then isntalled and the passiver crossover module was velcrowed to the inside of hte door panel. everything fits togehter very well.
the Driver side door went on the same way, with one exception, i was able to use the hole that fusebox's retaining pin uses to pas through the wire into the car, i trimmed the lower retaining pin clip off the fuse holder, and isnteadused heavy duty velcrow to secure the lowerpart of the fuse holder. the wire passes neatly out of hte fuse holder....
below are the pictures I took during the install.... this weekend I will finish the car with more pics
16psibrick's Avatar
Old May 31, 2004 | 04:25 PM
16psibrick's Avatar
Old Jun 1, 2004 | 01:34 AM
starbucks's Avatar
Looks very interesting, but more than I could do. How do they sound compared to the original Bose?
Also, what would that cost if I took it into a custom installation shop?
Old Jun 1, 2004 | 10:51 AM
16psibrick's Avatar
well, nothing is hookedup just yet, will be all done this upcming weekned, i simply installed the speakers and ran the wires out...judging from how the stock bose sounded, I hae no doubt the new system will sound much better
as far as taking it to a shop and having it done...well, some shops will charge only like 50-60 bucks but they probaly wont take all the steps, especially the dampening...but if you find a good shop with responsible installers, pay a little more and they will do a job just like this...
if someone came to my shop and asked me to do this, i would say probably around 50.
Old Jun 2, 2004 | 10:51 PM
DreamWarrior's Avatar
What's the mounting depth available back there? Just curious, if I do something I'm thinking about going with some 8" bass/mid-bass drivers...but I'd probably need a good 3.5" back there to do it. Is there clearance, or is the mounting depth pretty measly?
Edit: looked up the mounting depth of those crystals and it seems to be about 2.1", think I have another inch+ back there? Probably not eh...? Maybe build up a baffle...possibly, but then I have to worry about slamming the cone into the front grill....
Old Jun 2, 2004 | 11:10 PM
16psibrick's Avatar
well, i think if its around 3" it would fit, think soeting like a dei 8 whcih has the magnet upfront, or akicker rmb midbass...or a morel midbass 8" whcih is also less than 3"...i would estimate that there is about 3"
Old Jun 5, 2004 | 01:08 PM
Wow...I'd have expected less...that's good to hear...at least it opens my options up a little bit more. Now to find room for kick panels without losing my dead pedal....
Old Jun 5, 2004 | 01:57 PM
16psibrick's Avatar
if you want to do kicks, i would suggest going with a 3 way comp set, putting the 6.5": mid bass int he doors, and then only have a 3 or 4" midand tweet in the kicks, will definetly help you keep the kicks. my original pklan was to do just that in this car, but after talking to my friend, we decided to not go with kicks
i would thinka morel 8" 3 way comp set would be a fantastic set up for this car, with the 8 in the door, and the 4 and the 1 in the kicks, and give each side about 150 watts... i am drooling just thinking about it, it WILL be costly, but you will have great sound for sure.
b
Old Jun 5, 2004 | 02:02 PM
b
My last system was done by Sounds Impossible in NJ (Bill Acevedo, if you do IASCA you probably know him). It was incredible, I'm looking to match it if I do anything with this. Of course, it cost my 10k...but it won :D. I'm thinking an 8" in the doors, and a 3" dome mid and tweet in the kicks. I want the dome mid for its sensitivity, a mid driver isn't going to get the efficiency of a dome. I'm coming from a car with two Illusion horns with 101db 1w/1m sensitivity. Even with a 50w/channel Zapco amp driving them from about 1k up (no tweets in the car) they'd make my ears bleed. Topping that will be tough, and the horns won't go in this car .
edit: I had DLS 6.5" mid-bass in that car (which kept up pretty well) but I had them driven with about 300W. Prior to them I had Image Dynamics 6.5" which just couldn't handle the power. I think that having the 8" door room in this car (and the position of the speaker way towards the door's front) will hopefully really help the staging with the kicks and handle lower freqs. and more power.
Old Jun 5, 2004 | 02:19 PM
16psibrick's Avatar
hey, whats your name? i certainly know bill and omar, been to their shop once and chatted with bill, whcih I am sure he doesnt rmemeber, and have seen him at almost all the shows i went to. in my opinion one of hte nicest and certainly most talentented installers around, especialyl whenit comes to building comp vehicles.
unfortuantely i have not been to too many shows for hte psat year or so, i have no idea what the new batch of isntalls look like frmo them, i only know ryan chin's blazer, stripto's neon was it? and i think a celica and a few other cars I cant recall, and of course petracca's old benz, which i know he got something else to replace
Old Jun 5, 2004 | 02:30 PM
My name's Brian, I had a '96 Camaro. I competed in Novice 601+ class. Its been about a year now since my stuff was stolen and I have not had much time to keep in touch. Last I knew, though, Omar left after he graduated. They're all great guys and they have a great shop. I just wish I had the money to do it all again.
Old Jun 5, 2004 | 05:39 PM
bureau13's Avatar
Why do you guys want to put tweeters in the kick panels? High frequency sound is so directional, I've found any time you put something like that lower and to the side, my leg tends to drastically affect the sound if i move it. Putting them up by the A pillar or sail panels or whatever may not be ideal when you simply look at the "speaker system," but when you factor in the environment in which you will be using it, it seems to work better.
Just my ignorant amateur opinion... :-)
jds
Old Jun 5, 2004 | 07:18 PM
16psibrick's Avatar
well, personally, i find htat some automotive tweeters are mor directional than others, but in the past, i have been able to achieve good staging with most speakres with the tweet and midrange in the kick panels. according to richard clark, sound has a good way to going around your legs or other small blocking things and not be severely affected...
the a pillar mount is also a good location for tweets, personally I only used them a few times to bring up the sound stage with a second pair of attentuated and perhaps time delayed tweets up there, but I know people have achieved great results with the tweets up there, anthony davis's ford contours comes immediately to mind...but perhaps i just dont have the skill neccessary to make cars sound good with tweets up there alone by themselves
b
Old Jun 5, 2004 | 07:59 PM
MrWigggles's Avatar
jds
With manual transmission cars, I use the dead pedal a lot. with my left leg there the highs are blocked if I keep the tweeters down low where the stock 9" speaker is.
kick panel in Automatic transmission vehicles usually works better especially if there isn't any passenger in the car.
Ultimately I plan to do a Dolby Pro Logic II music mode set-up and utilize the Bose center channel location (90% chance I won't use the Bose speaker)
Anyway, in two channel cars, I think the best location for tweaters is in the sail panel in the a-pillar when kick panels aren't an option for whatever reason.
Thanks 16pisbrick for the pics.
-Mr. Wigggles
Old Jun 6, 2004 | 01:09 PM
jds
Depth of sound stage in kicks is way better than inches (well a foot maybe) from your head.
Old Jun 6, 2004 | 11:01 PM
bureau13's Avatar
Maybe if I hack off one of my legs (and make sure I have no passenger with a right leg) I'll be able to tell. Seriously, how do you get around that? I read the other comment about how in theory blah blah blah...well, in practice, it sounds like crap when a fairly large and solid object is passing between my ears and the tweeter. Are some tweeters really more sensitive to this kind of thing than others?
jds
Old Jun 7, 2004 | 12:44 AM
jds
Depends on how it is positioned and designed. How it is aimed also affects it greatly. Really, the end goal is to acheive as equal distances as possible from all speakers in the car. This is harder in the sails because one is a lot closer than the other, but in kicks they're both semi-far away so the two distances are closer to the goal. Sound, however, is pretty good at travelling through/around your legs...but it does reflect and therefore you have that to contend with as well. Its all a balancing act...in general though I find the kicks to be a better place to attain closer to ideal staging conditions.
Old Jun 7, 2004 | 08:03 AM
bureau13's Avatar
If you...or anyone else...has any detailed pics of a kick panel tweeter installation in the RX-8 I'd be interested in seeing it. The sound stage/equidistant point is a good one.
jds
Old Sep 14, 2004 | 11:52 PM
jvolpe's Avatar
16psibrick: how did you get the wires to the back of the car? did you run your own wires to the back, or tap into theirs on the floor board?
Old Dec 28, 2005 | 10:39 AM
BomberNYC's Avatar
rotarywanker
Dec 8, 2022 05:56 PM
RXeckless
Aug 16, 2015 12:52 PM
akagc
Aug 11, 2015 07:07 PM
yapakanichi
Jul 21, 2015 08:43 PM
Majictoast
Jul 18, 2015 06:45 PM
