Will evo 8 brembo brakes fit on our 8's
Old May 23, 2004 | 06:53 PM
army_rx8's Avatar
X-Sapper
I was wondering if anyone knows if Brembo brakes off of an Mistubishi Evolution 8 would fit on an RX-8? I believe the evo has 17" front and 16" rear brake rotors...with brembo 4 piston calipers.
Old May 23, 2004 | 09:15 PM
dcfc3s's Avatar
RX-7 Guru
Who knows. You can really fit most any brake caliper onto anything, as long as you have the correct bracket with the right spacing. Engineering brake setups can be tricky - goof something up, and you can die, no fooling.
The RX-8 has REALLY good brakes as-is. I do know that Mazdatrix has a big brake kit with large front calipers and rotors. Pricey, but I bet those Mitsu calipers wouldn't be cheap from the parts counter either.
Dale
Old May 23, 2004 | 10:51 PM
himitsu's Avatar
Why would you want to do that?
There is already a Brembo made to fit the RX.
You will need spacer if you still use the OEM wheels, because the space is too tight on those...
But if you have replaced your wheels to a better racing wheels, then should be no problem...
BTW they also sell the spacer too.
http://www.mazdatrix.com/8brakes2.htm
Old May 23, 2004 | 11:52 PM
epitrochoid's Avatar
Riot Controller
just have a machine shop make you some brackets. as long as the rotors fit our hubs you should be fine with a set of spacers
Old May 24, 2004 | 08:13 AM
310Guy's Avatar
4AT poor mileage king
Definitely.
Unless you plan on some SERIOUS racing (not on public streets!) there isn't any reason to upgrade to another brake system.
However, if you want to "look cool" then the Brembos are a good way to throw away some money.
Old May 24, 2004 | 10:37 AM
army_rx8's Avatar
X-Sapper
thanks you al for the imput.....the reason i was asking this is because i have a set of them alying in my house...long storyu on how i got them..but they were free so what the hell.
Old May 24, 2004 | 11:46 PM
himitsu's Avatar
Lucky you...
Just get the spacers then... or better still replace your wheels with something 19, and open to better show them big brembos...
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Road Cone
Nov 6, 2015 01:52 PM
airlive
Sep 7, 2015 08:32 PM
