when A/C on, RPM goes low? anyone has this problem?
Old May 20, 2004 | 09:15 PM
louis1128's Avatar
Question when A/C on, RPM goes low? anyone has this problem?
when I turn on A/C on my 8 , RPM goes low. and cause a little virbrate, and then the RPM goes back up again anyone has this problem?
any advise?
Old May 20, 2004 | 09:19 PM
RotorMotor04's Avatar
RX-8 "SE3P"
I dont know if i have ever experienced this in my 8, but my Celica did the exact same thing
Old May 20, 2004 | 09:33 PM
w2aew's Avatar
www.dorkage.com
Perfectly normal. The A/C compressor puts a load on the engine when it kicks on, and that causing the change in the idle RPM.
Old May 21, 2004 | 09:46 PM
MrH's Avatar
MrH
When the AC is turned on, you are basically connecting the engine to the AC compressor, putting a load on the engine. The engine then has to compensate, but opening up the throttle a little, so it won't stall and go back to normal idle RPM.
xAgyex
Jun 3, 2026 03:47 PM
ironj221
36
Jan 20, 2026 08:28 PM
uZu
Dec 30, 2015 12:35 PM
Solmors
Aug 21, 2015 10:11 PM
Belalnabi
Jul 17, 2015 07:48 PM
