Any fixes for engine ticking and exhaust rattle
Old May 20, 2004 | 01:50 AM
Edmonton s/silv's Avatar
Edmonton, Silver GT
When i start my rx8 it has a obvious ticking noise....as well it is beggining to rattle from the back..i suspect the exhaust????
Old May 20, 2004 | 03:53 AM
or maybe http://www.finishlineperformance.com...er_recall.html
Old May 20, 2004 | 04:56 PM
rotaryDemon's Avatar
maybe the resonator hitting the heat shield.
Old May 20, 2004 | 07:18 PM
mikeb's Avatar
100% Italian
I have a AT
and it makes these noises
Old May 20, 2004 | 07:28 PM
RX-8 friend's Avatar
The ticking is the injectors. You don't want to stop that . The rattle could be the heatshield recall not done or the exhaust hitting the body. Have it checked out for that.
Old May 20, 2004 | 08:16 PM
if it is only when moving, check your lug torque. a tsb has been issued for that also. 105ft lbs.
Old May 20, 2004 | 08:42 PM
Kel Rx8's Avatar
if your not 1st your last
my friends 8 makes a similar noise
its horrible sounds like the cat. but car has all recalls done.
Old May 20, 2004 | 09:37 PM
w2aew's Avatar
www.dorkage.com
I also remember reading that there is an auxiliary air pump that runs when the engine is first started to help bring the cat up to temperature. That could be part of the ticking you hear.
vapor2
Nov 3, 2020 03:38 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
dbarber
Jul 25, 2015 01:34 PM
Belalnabi
Jul 17, 2015 07:48 PM
