My first CEL
Old May 12, 2004 | 09:25 PM
Nordic RX-8's Avatar
My first CEL
On Tuesday, my CEL came on and stayed on as I was driving down the interstate - 2225 miles on the odometer. My dealer got my 8 into the shop today - code was P0420 catalytic converter below specifications. The paperwork says they re-flashed the PCM but there is no indication of the version number (or letter). Does the re-flash mean an update? Or did they just reload the current version? I was in a hurry to get back to work, and the service writer was not sure. This was the first visit to the dealer)
Old May 13, 2004 | 07:52 PM
RX8by's Avatar
It seems the RX8 is very sensitive to the catalytic converter below specifications meaning the temp got to low. Either the ECU flash up to the "m" flash will fix it or another sensor will have to be replaced. I have been bless with no lights and a great running 8 which is good since I have a July 2003 vintage. The M flash has smooth the engine out and gave me mileage from 16.6 to 18.2 in mixed driving.
Old May 13, 2004 | 09:03 PM
RX8by -
how do you know what version is loaded? I don't really notice any performance difference (it is still great). The only thing that I can tell that is different is that they seemed to have moved my vehicle information sticker that used to be on the driver-side front door to the driver-side back door. ( It also seems that the tire pressure spec. sticker is different, as it now calls for 32 psi front and back where it used to be 33 psi). I guess I will wait until I take her in for the free dealer oil change and then make a point to talk to the rotary techician.
Old May 14, 2004 | 12:17 PM
rxeightr's Avatar
M0D Squad -charter member
I had the same code back in February. When they re-flashed, the dealer installed a sticker on the bottom of the hood, near the latch specifying what upgrade was used for the re-flash.
I have had no further CEL codes since.
RevMeHarder
Jun 1, 2026 02:30 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
