Feasible to shut one rotor off for cruising?
Old May 11, 2004 | 05:35 AM
PhineasFellOff's Avatar
The technology has been tried before on piston engines. This fall, Honda will introduce an Accord Hybrid (with a supplementary electric assist motor) that will also have VCM (variable cylinder management), which will shut off one bank of three cylinders during hwy cruising to increase gas mileage.
Is it possible for the two-rotor Wankel to cruise on one rotor only? Could one rotor cruise efficiently and thus get greater mileage?
Old May 11, 2004 | 05:38 AM
flatso's Avatar
I'm Tantalizing
you can get that already on the new Chrysler 300 hemi
Old May 11, 2004 | 05:48 AM
waldo's Avatar
04 6MT
Gains are minimal. YTou have to figure that the now smaller engine has to work harder, using more gas. GM is gnning to use it in most of their vehicles soon, and projected savings are 15%. You can save much more than that by not driving so agressive.
Old May 11, 2004 | 07:56 AM
jtimbck2's Avatar
I remember when I was a kid we had a 1976 Chevy Caprice station wagon -- it had a 4-barrel carburetor that would cut back to 2 barrels for cruising.
Old May 11, 2004 | 09:43 AM
Sue Esponte's Avatar
Grand Poobah
Cadillac used to have a v4-6-8...horrible failure of an engine but the newer piston shut down technologies are supposed to be a vast improvement over the past. It seems like a neat idea but in the long run I wonder how much of it is really worth while in terms of fuel savings.
-Eric
Old May 11, 2004 | 09:58 AM
GiN's Avatar
GiN
ロンリードライバー
-Eric
My 1981 Coupe DeVille had that 4/6/8 thing. It didn't help diddlysquat. :D
Old May 11, 2004 | 10:06 AM
Gigolo Jason's Avatar
The Thread Hijack King
The rotary engine works like a pump. It is constantly moving and sucking and blowing. I supose it could be done iwth indipendant throttle bodies, controld systems, and fuel systems for each rotor, but not as it stands now.
I would also argue that this would increase wear on the rotor that is shut off and not allow the engine to balance itself properly while running.
Old May 11, 2004 | 10:18 AM
Senseny's Avatar
Wouldn't the engine need two separate e shafts that are independent of the other for that to even be a possibility.
Old May 11, 2004 | 11:26 AM
mamccubbin's Avatar
Bert angry!
I had a Datsun 210 that only had three of its four cylinders working. Does that count?
Old May 11, 2004 | 11:33 AM
Doctorr's Avatar
Ricer is Nicer.....
Cool No gain....
Like Gigolo Jason says the rotary is basically a pump, if you shut off fuel and spark, it would still be using energy 'pumping'. If you shut the throttles, it would get worse, trying to pump a vacuum.
The piston versions worked by leaving the valves shut all the time, causing an 'air-spring effect'. The piston would compress the air, then be pushed down by it, with little net loss.
doc
Old May 11, 2004 | 11:43 AM
ricks8's Avatar
Actually, Internal Combustion Engines are most efficient when operating at full throttle. Sounds counterintuitive, but thats why a flogged econbox gets better milage then a muscle care limped along.
See this article
http://www.caranddriver.com/article....&page_number=1
Old May 11, 2004 | 11:46 AM
IKnowNot'ing's Avatar
Re: No gain....
doc
Exact and the system works by entrapping combusted gases (instead of fresh air) into the chamber in order to keep it warmed-up.
Old May 11, 2004 | 11:47 AM
cas2themoe's Avatar
PoloRican Rotary
I heard of that last year, their were testing it out in Chevy trucks
Old May 11, 2004 | 11:59 AM
we had this discussion some time ago in this thread and as mentioned- you dont need to shut off one whole rotor just skip a cycle per rotor. but this question on our urging was also put to Mazda by rotarynews.com and they answered "No". i think they are working more towards hybrid and hydrogen to increase fuel economy and decrease emissions
Old May 11, 2004 | 12:27 PM
88gt's Avatar
No it's not feasible. The e-shaft won't allow it.
Old May 11, 2004 | 12:50 PM
They are most efficient when at full throttle and at full RPM, yes, but they are not designed to run continuously at this pace. Most piston auto engines are designed to run at 30% of there rated power continuously. The opposite end if piston aircraft engines that are designed to run at 75%-80% of there rated power continuously.
The currect e-shaft won't allow it but double e-shafts have been produced in the past. The 20B had a two piece e-shaft.
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
titaneum_grey
Sep 6, 2015 10:21 PM
