JL e4300 amp good for the 8?
Old Apr 26, 2004 | 06:41 PM
Japan8's Avatar
Int'l Man of Mystery
What is the power rating of the amp? Stock speakers often times can't take much in the way of power at all. Thus any power level above the HU's is too much for them.
Old Apr 26, 2004 | 07:22 PM
Japan8's Avatar
Hmmm. Looks a little too powerful for stock speakers. Generally most people would swap their speakers out BEFORE buying an amp when trying to imptove their system. Your complaint is about noise and the inherent weakness of FM transmitters over AUX inputs... another solution might be to wait for OverLOAD's Aux module and work your way up from there...
Old Apr 26, 2004 | 08:43 PM
bureau13's Avatar
Unless you're REALLY cranking it, more speakers are damaged from underpowered amps than overpowered ones. In fact, if you're really cranking the underpowered stock amp and its clipping, that's the worst thing you can do to your drivers. However, changing out the speakers is probably the single biggest improvement you'll make in your sound quality, so go ahead and blow the stock suckers! You'll be glad you did in the long run.
jds
Old Apr 27, 2004 | 08:36 PM
Japan8's Avatar
Yeah... bureau13 does have a point. So blow those crappy speakers... so you can buy some new one to replace them. :D
My only thought has been that is an amp really the solution to this problem? The problem isn't that the headunit's amp is weak, rather the FM modulator is giving you a weak signal and so your input level is low. Sure turning up the volume helps here, but your noise also increases... Thus I mentioned the aux module earlier.
rotarywanker
Dec 8, 2022 05:56 PM
delicious_dallan
Jan 17, 2020 09:17 AM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
ei8ht
Aug 21, 2017 09:08 AM
talonhart2
Aug 26, 2015 04:14 PM
