Yokohama - AVS ES100
Has anyone tried them? I am looking for tires, and there are not too many options with 225/45/18. And I wouldn't like to get lower profile tires.
So in my search I came acrosss these AVSES100 Yokohama's. My problem, I have never used them. If anyone has any experience, I am all ears..
http://www.yokohamatire.com/TireIntro.asp?TireID=9
Actually, Tirerack.com shows 8 different tires in that size... check it out, here.
As for which tires to pick, first decide what you want them to do. Max summer/dry road performance, max winter/slick road performance, or best compromise between the two extremes. Then based on what you want, start reading the customer reviews on Tirerack about the specific tires that fit your needs, and pick the one that you like the sound and look of the best. It's also a good idea to look at the treadwear number, as some tires (numbers below 200) will wear out quickly.
Finally, I'd also suggest you don't limit yourself to just the one size you listed. Lots of different widths/sidewall heights will fit on the RX-8's stock wheels, and if you go with a different size, it expands your selection in tires quite a bit. For instance, while the stock size is 225/45-18, I went with 245/40-18s, and they fit (and look) great! Spend some time hunting around in this forum to find out what sizes fit.
Coupla more things, now that I think about it...
First, a great tire size calculator that allows you to actually see what the different sizes look like on the wheels is here. The same site also has a great explanation of what all the sizing info means, here. And finally, if you want Ultra High Performance all-season tires, I can highly recommend the (oversized, 18") Pirelli PZero Nero M+S tires that I went with. You can read about them, here.
Hope this helps!
Hope this helps!
I have been doing a lot of research and it looks like those tires are soon to be on my car as well Omicron. I dont need to worry about snow over here, but they also got great dry and wet handling as well as a good tread life. Cant be beat for 150 bucks each.
I used these exact tires, though in a different size. I had AVS ES100s on my Mitsubishi 3000 GT in 225 / 55 / 16.
I loved those tires. They were excellent, both as sport tires when carving up twisties, and in the rain. I would highly recommend them, especially at the price they cost.
---Andrew
---Andrew
Hope this helps!
Hope this helps!
Originally posted by flatso
They are a very good tire for the money. This is from feedback on the Roadfly Z3 board I have never used them myself.
---Andrew
---Andrew
Originally posted by RX8-TX
...I couldn't find rating for Yokohama.
Also, you may be interested in the AVS ES 100 data sheet off the Yokohama URL you posted.
Originally posted by rx8cited
Yokohama AVS ES 100 - Treadwear: 280, Traction: AA, Temp: A. Please let us know how you like them if you get them.
Thanks Omi!
Thanks everyone!...will soon have to make a decission since the Potenza's are close to expire.
Happy to help. :D
But, if yourPotenzas are close to expiring, I'd be curious as to how many miles do you have on them?
Happy to help. :D
https://www.rx8club.com/showthread.php?t=38107
I have a set of them for sale right now!
Still available too!
:D
:D
I'm looking at BF Goodrich Comp TA KD tires (no need for the all weather of the KDW) or the Michelin Pilot Sport 2's Both are pretty much the best tires out there. I will probably go to 245/40/18
Originally Posted by RX8-TX
245/40s should give you almost exactly the same overall diameter, right?
https://www.rx8club.com/showpost.php...35&postcount=7Diameter Difference: 1.01%
Since the 245/40 is wider, are their any rubbing problems with it?
rx8cited
225/40R18 - Overall Diameter: 25.08 in 637.03 mm
245/45R18 - Overall Diameter: 26.68 in 677.67 mm
245/40R18 - Overall Diameter: 25.71 in 653.03 mm
Hope that helps!
Originally Posted by rx8cited
Try the calculator you quoted in this post of yours
rx8cited
rx8cited
I assume you will use stock wheels. The stockies are 8" wide.
With the 225/45/18 & stock rims, you get an overall diameter of 25.97" - If you go from 225 --> 245 & 45 --> 40, the overall diameter of the tire won't be affected that much. Why? the aspect ratio is lower, but width is greater. One compensates for the lack of the other....
Anyways, here is a good read:
http://www.enjoythedrive.com/content/?id=25824
And I don't think you'll have serious rubbing problems...the big issue is when you upsize your wheels as well. If you keep the stock ones (8" wide) & the 245s fit....no drama.
