Buger and others! What do you think?
Old Feb 11, 2003 | 08:00 PM
chenpin's Avatar
This is for all the kung fu masters out there :D . I came across this and was wondering if any of you can verify this.
The gear ratios and power curves for the RX-8 are available, so it is possible to do a comparison of acceleration between the 8 and the Z. Though it is just an "on paper" calculation, it is still a relatively good indication of how the cars will match up. The first interesting point is that the Z and the 8 have very similar torque curves. Second, Mazda seems to have chosen some funky gear ratios...not quite optimal for 0-60. Some people are guessing that this was done as a compromise in favor of economy...the car is a four door after all. After plotting acceleration through the gears for both cars, here are my predictions:
0-60, stoplight races, or anything at low vehicle speeds: The Z will own the RX-8. Like I said, the gear ratios are funky in the 8. If Mazda revises the ratios later for quicker low speed acceleration, Zs may have some difficulty.
Anything above 50: The 8 and the Z have nearly identical acceleration. What this means is, if you own a Z and want to race an 8, don't do it from a roll on the highway...neither one of you are likely to pull much on the other. This also means that if the 8's handling is up to snuff, the Z will have stiff competition on the road course.
Anyway, those are my predictions for a Z vs. 8 match-up. I'll be the first to say that this is entirely bench racing, so like many others have said wait until the 8 comes out before making any final judgements.
One final interesting note is that one of the reviewers who was present at the RX-8 Laguna Seca press day borrowed a 350Z to do a comparison between the cars. On the subject of torque, he said the 8 had "good low-down torque" while the Z "lacks much in the way of low-down torque". Things may not drive the way you expect them to, so wait till you can drive both before you make a choice.
Both cars carry 90% peak torque over a significant percentage of the rev range. But don't be fooled by the torque numbers...the Z doesn't really have all that much more torque than the 8. The area under the torque curve is what really matters for acceleration. While the height of the Z's torque curve is greater, it does not span the rev range that the 8's curve does. Compute the area under the curves, and you'll find that the torque of the two engines is much closer than you think. To make a more simplified comparison between the 8 and the Z, consider the 8 to make 240 lb-ft with a 6000 RPM redline and 90% peak torque coming in by 2166 RPM. This will tell you how the car drives and accelerates. Of course, 240 lb-ft is still less than the Z's 274, but please remember that the Z also makes ~40 more HP than the 8.
Like I said, I think the Z is going to own the 8 from a standing start...but the reason is because of the gearing Mazda has chosen, and not because of the Z's (perceived) torque "advantage".
the 350Z curve is much taller than that of the RX-8, but the RX-8 curve is significantly broader. Visually try to compare the area under the curves, and you'll see it's not that big a difference.
They don't use a similar amount of RPM range on each gear shift. As an example, the Z upchanges from 1st gear to 2nd at redline, and the tach drops to ~4250 RPM. That means that the entire 2nd gear pull will cover a rev range of 2350 RPM. In contrast, the RX-8 makes the upchange to 2nd at 9000 RPM in 1st, and the tach drops all the way down to 5250 RPM. The 2nd gear pull for the RX-8 will cover 3750 RPM on it's way back up to 9000. The RX-8 will sweep 1.6 times the revs the Z will during 2nd gear. That means the RX-8 torque to the wheels is getting multiplied ~1.6 X more than in the Z, since gearing directly multiplies torque. It's like the RX-8 was making 1.6 times it's torque with a lower redline...1.6 x 160 lb-ft = 255 lb-ft. Like I said, they really aren't that far off.
These were posted by "Red Rotory Rocket" on my350z.com. I think what he's saying makes sense, but i'm not a tech guy so can anyone comment on this?
Old Feb 11, 2003 | 08:18 PM
chenpin's Avatar
Opps!
Sorry Herc, i forgot about comparisons in this forum. Can someone kindly move this to RX-8 discussion?
Old Feb 11, 2003 | 09:02 PM
Hercules's Avatar
No I think this is the appropriate forum for this discussion.. let's just keep it onto the technical facts and not into a flame war
*will stay quiet* :D
Old Feb 12, 2003 | 01:04 PM
Buger's Avatar
RE member
It all really depends on the weight of the RX-8. I haven't really posted many simulations recently because I've been hoping to hear something about the final weight of the RX-8.
At this late stage of the game, the weight should already be known since all of the production dies and stuff are already finalized. Mazda has previously advised that Job1 will be in before the end of their fiscal year which is March 31. I'm not allowed to mention the exact date.
From what I have done, the 350z is still faster than the RX-8, even at higher speeds. The 350z was built for a different purpose than the RX-8 and any acceleration comparisons should really be done with the G35.
Still, every single comparison I have previously done with RX-8 (weights ranging from 2850 to 3011 lbs) has the RX-8 beating the 350z from 50-70. This is because the RX-8 can stay in 2nd gear (higher wheel torque) while the 350z can't. The RX-8 and the 350z will also probably be neck and neck from 0-70 (A 3000 lb Rx-8 that shifts at 9500 rpms actually comes out .01 faster).
Because the RX-8 was built for a different purpose than the 350z, it was geared for a different purpose as well. The rx-8 gearing ratios seem to be chosen to emphasize the wide powerband of the renesis more than to emphasize maximum acceleration. Hearing the statement "1.6 x 160 lb-ft = 255 lb-ft", any 350Z enthusiast could point out that the 350Z engine already makes 274 ft-lbs so doesn't need any "additional" gearing.
Redrotaryrocket is a member of this forum as well as the Rx7forum. I'm sure he can probably post some of his stuff up when he has the time.
Brian
Old Feb 12, 2003 | 08:54 PM
Supercharger's Avatar
We have to look at the Tractive Force vs. Speed graph of both cars to get a better idea.
Here is a sample graph. The car is a modified BMW M3.
Old Feb 12, 2003 | 09:01 PM
TF-S graph
You can figure out the best shift points from a TF-S graph. This applies to cars with manual gearbox.
The TF-S graph will look different for a car with CVT gearbox.
This is a good reference:
http://www.mvs.chalmers.se/~thomson/...ture-OH-x1.pdf
Old Feb 27, 2003 | 01:46 AM
PsYcHo_Pilot's Avatar
close, but not til the mods
I reckon, even if the 8 is a lil slower, who cares, that can always be fixed with a turbo, extending the ports etc etc and any way, the 8 in my books looks a hell of allot better.
Weight reduction would obviously come first, and lower the car too, apparently it rolls a lil too much if you want to fit in the sporting range.
I'm no expert, but if the Renasis has the same potential as the old 13B, then i have a feeling the competition is gonna be left licking its wounds
Old Feb 27, 2003 | 03:45 AM
wakeech's Avatar
mostly harmless
Re: TF-S graph
the rev buzzer works well too :p ahahaha...
:BUZZ: one-one-thousand, two-one-thousand, three-one-thousand, four-one-thousand...
Old Feb 27, 2003 | 07:31 PM
Optimum shift points are intersection of tractive force (blue) lines.
The M3 graph shows a close ratio 5-speed gearbox.
If the TF lines do not cross-over, shift just before redline.
Gear ratios that are too far apart causes the TF lines to separate.
In general, gearing is important for low-torque engines.
A car with a high-torque engine can accelerate hard in any gear.
Old Feb 28, 2003 | 07:56 AM
fromcast's Avatar
Gear ratios and other stuff
Sorry, it is in French. You'll figure it out, off course.
Rapports de démultiplication RX-8
5-vit 6-vit
1ère vitesse 3,483 3,760
2e vitesse 2,015 2,269
3e vitesse 1,484 1,645
4e vitesse 1,000 1,187
5e vitesse 0,762 1,000
6e vitesse - 0,843
Marche AR 3,288 3,564
Couple conique 4,444 4,444
The complete technical file (in french) is attached.
Old Feb 28, 2003 | 08:55 AM
cagefreak's Avatar
Brian
I would have to agree. It all depends on the RX8's weight after production. No doubt that the 9.5 redline helps whip it around on the track.
Example: 2000 Celica GT-S Weight: 2580 (with me 2713)
Redline: 8.5
Respectably, I didn't have all that much trouble getting past clubz.org's 350z pack. In fact, the only reason why is because I still had power coming out of turns while a lot of the 350z owners said they would have to imediately shift almost right after coming out of a long sweeper.
-justin
Old Feb 28, 2003 | 06:11 PM
Tractive Force:
Old Feb 28, 2003 | 08:16 PM
Tractive Force:
but your attached diagram reads as "traction force"
Old Feb 28, 2003 | 08:38 PM
Traction Force and Tractive Force are the same thing.
Tractive force (TF) decline as speed increase.
Tractive resistance (TR) increase as speed increase.
TR = Friction + Aero Drag
When TF = TR, a car has reached its top speed.
If you have access to a chassis dyno, TF-S graphs can be generated.
Old Feb 28, 2003 | 08:50 PM
then why not use one term instead of two, it's abit confusing if you ask, saying one thing and meaning another. perhaps you should fix your diagram?
Old Mar 1, 2003 | 09:54 PM
Acceleration = (TF - TR) / Mass
TF: blue lines
TR: black lines [ 0% = flat road ]
___________ [> 0% = going uphill ]
Old Mar 2, 2003 | 08:01 AM
rxeightr's Avatar
M0D Squad -charter member
Quote from Buger:
In the 4/03 Car & Driver comparison article between the RX-8, the G35 Coupe & the Mustang Cobra, this is what their 3 days of testing came up with ---
RX-8 0-60mph--5.9sec 0-100mp--15.8sec 0-130mph--33.5sec
5-60 mph--7.5sec 30-50mph--10.8sec 50-70mph-10.0sec
G35 0-60mph--5.5sec 0-100mph--14.2sec 0-130mph--26.8sec
5-60mph--6.2sec 30-50mph--9.2sec 50-70mph--8.8sec
Cobra 0-60mph--4.6sec 0-100mph--10.6sec 0-130mph--18.4sec
5-60mph--5.4sec 30-50mph--8.2sec 50-70mph--7.6sec
Old Mar 2, 2003 | 09:28 AM
wakeech's Avatar
mostly harmless
that was the G35C, or 4 door?? or are the numbers similar?? (i should go read the article... :o)
Old Mar 2, 2003 | 11:44 AM
rxeightr's Avatar
RXEighter says:
G35 Coupe
Old Mar 2, 2003 | 08:43 PM
Buger's Avatar
RE member
Quote from Buger:
Hi rxeightr,
It appears that the 30-50 and 50-70 times were done in top gear. Since the RX-8 6th gear is strictly for fuel economy, it is not indicative of the actual performance. The RX-8 30-50 and 50-70 times are both likely to be between 2.5 and 2.7 seconds.
Brian
Old Mar 2, 2003 | 08:49 PM
wakeech's Avatar
mostly harmless
Hi rxeightr,
Brian
pardon my french, but that seems ******' retarded to me...
why not just do the test in the 1.000 ratio gear for all three cars??? wouldn't that give a far more even test?? i don't think that for comparison's sake the reduction in timed difference would impact the outcome, due to error or anything like that...
Old Mar 2, 2003 | 09:03 PM
revhappy's Avatar
Hell, why not use the gears in each car that optimally accelerate throughout the given ranges of speed? That's what people will do in the real world. Personally, I have no problem downshifting to get the most out of the engine's powerband.
Anyone know what kind of track they used? Hopefully, it was a Nascar track!
Old Mar 2, 2003 | 09:15 PM
Excel spreadsheet for car performance map calculation:
http://www.triumphnet.com/st/faq/per...erformance.htm
Click on one of the .xls links to view the program.
Omicron
Mountain Forum
16
Feb 4, 2004 09:40 PM
Hercules
Jan 7, 2003 06:58 PM
