K&N Installation
Old Mar 30, 2004 | 07:57 PM
RX8FanMan's Avatar
JRizzle
K&N Installation
does anyone know how to install this intake? I really dont want to pay someone to do it.
Old Mar 31, 2004 | 11:49 AM
BoxerGT2.5's Avatar
Do a search...it's out there.
Old Mar 31, 2004 | 12:50 PM
Speed Racer's Avatar
Certified track junky!!!
You can download a PDF of the instructions from K&N's website.
Old Mar 31, 2004 | 01:24 PM
BoxerGT2.5's Avatar
The intake also comes with the same instructions as the PDF on the website. Pretty easy to follow.
Old Mar 31, 2004 | 02:55 PM
RX8FanMan's Avatar
JRizzle
alright thats good, i really dont want to pay someone when i could save money for more stuff for my 8
Old Mar 31, 2004 | 03:00 PM
RX8FanMan's Avatar
JRizzle
there are different types? whoa which one should i get
Old Mar 31, 2004 | 09:15 PM
BoxerGT2.5's Avatar
Those different types you looking at are the various colors and finishes. Just make sure you get one with a heat sheild.
Old Apr 1, 2004 | 12:52 AM
rotarygod's Avatar
If every different system is essentially the same design, it stands to reason that no on eintake system will be very different from another. K&N and Rotary Extreme both offer heat shields for their systems. They are both about the same length. they both use cone filters but the K&N filter is larger. You can not get too big of a filter from a flow standpoint but the size of the K&N may affect airflow through the original airflow location from the front of the car. AEM is also about to releas an intake and theirs will be basically the same type of setup. They are all going to be fairly loud. There are ways to help quiet them down a little bit posted here on the forum somewhere.
The whole point is to go with your gut instinct. You aren't going to get a noticable improvement using one system over the other. If this is your only mod, you aren't even going to feel a difference in power although the added sound will make you think you do. This doesn't mean that you won't get a power gain though because you will. If just isn't impressive. Pick the one you think best suits your taste.
Old Apr 1, 2004 | 04:42 PM
AEM_Tech's Avatar
Please do not spread misinformation. The owner of the test car hasn't even seen the intake yet and I doubt you have seen it.
Old Apr 1, 2004 | 04:54 PM
haha false info...its all over this forum..
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
