Will this ramp fit the 8?
I just bought a set of Rhino Ramps so I could do my exhaust myself. I got the 8000lb capacity not the 12000lb ones tpryor has. I had no problems clearing them going up or down.
flatso, the only reason you can come off the ramps are if you do something wrong. They are easy to get up on. If you have a 6mt then you can use the E-brake to help modulate speed.
BTW, they were $17.99 at Pep Boys.
I bought a set a Wal-Mart for like $20 bucks that work great. Barely clears in the front (with appearance package) -- now that I have the MS bodykit -- ramps are a no go
-- the price you pay I guess. Also can't use the jack rails on the side -- heck I had to raise the JIC's up just to be able to get a jack under the car.
Yep -- Rhino Ramps, Pep Boys, under $20 for the set.
I can't figure out why anyone would pay over $40 plus shipping for the same things.
They won't work on our lowered Miata, but they work on the stock Miatae and the 8 just fine.
Originally posted by Aratinga
Yep --
Yep --
Originally posted by flatso
I guess you have no problem with them hitting in the front Velocity? Looks like we have a winner I think I will get those. Thanks my NJ friend!
One thing you can do is use a 1 inch thick board right before the ramps. This will give extra clearance.
Re: Will this ramp fit the 8?
Ramps
I want to get some low rise ramps and was wondering if these are any good or if anyone could recommend one.
Ramps
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
