adjustable camber
Old Mar 24, 2004 | 07:49 AM
rotaryDemon's Avatar
Question adjustable camber
do our cars come with adjustable camber? if not, does anyone make them?
Old Mar 24, 2004 | 08:45 AM
XeRo's Avatar
Normality is Obscene
depends on how much adjustment needs to be made...i think there is minimal adjustment available on the stock setup...maybe someone who has done suspension mods already can chime in on this...as I haven't even looked since I am still undecided on what to do suspension wise yet...
Old Mar 24, 2004 | 08:52 AM
tpryor's Avatar
Re: adjustable camber
Yes.
Front Camber, Caster, and Toe are all adjustable, and rear Camber and Toe are adjustable.
Old Mar 24, 2004 | 06:27 PM
thanks for the help fellas. i am planning on the springs from mazdaspeed. i think i saw a .75 drop, after i install the rims. volk 57f pro 19"
Old Mar 25, 2004 | 06:11 PM
VividRacing.com's Avatar
JIC will be releasing some more suspension items in the near futrue that will allow more adjustment. The current setup can be adjusted but is limited in some respects but if you looking to just adjust back to the stock specs after the springs and rims then you will be OK.
Old Mar 26, 2004 | 06:25 AM
GTRay's Avatar
mmm... tastes like jesus
yep,
i had my car up on our alignment rack last month to correct a slight pull to the right and can confirm that indeed we have pretty decent camber and caster corrections available from the factory.
not many imports give you caster and camber adjustments from the factory, most of the later cars require aftermarket kits.
setting the alignment on the 8 was cake!
Ray
Old Mar 26, 2004 | 08:50 AM
thanks...i am not really sure if i would even need to drop the demon ride. i am hoping the tires will fill the gap between the fender and the wheel.
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
duworm
Oct 1, 2015 04:57 PM
titaneum_grey
Sep 16, 2015 11:51 PM
