Hazy film on inside of headlights and instrument cluster
Old Mar 23, 2004 | 06:34 PM
boxerdad's Avatar
Just took delivery of a silver automatic. When the headlights are on, I notice that there is a hazy film on the inside of the clear plastic lens assembly on both passenger and driver side. Also, there is a hazy film on the inside of the clear plastic over the instrument cluster. The dealer says that nothing can be done as this is due to moisture inside the headlamp assys., and that removal of the dash required to clean the inside of the plastic may cause rattles and squeaks after the dash is re-assembled. Has anyone else out there noticed/experienced this?
Old Mar 23, 2004 | 07:01 PM
zavhan's Avatar
Had similar problem to wat u have mentioned.
However the hazy film is on the outside of the dials and headlamp.
Had since removed it using CD scratch removal cream (audio shop[).
Apply a little and rub in a circular motion, tat will do the job.
It works fine with mine !
Hope it will hep u.
He||hammer
Sep 29, 2015 09:40 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
