Ceramic Rotary Engine
Old Feb 3, 2003 | 06:19 PM
Supercharger's Avatar
http://www.ultrahardmaterials.com
Old Feb 3, 2003 | 06:54 PM
velociti's Avatar
I think it would be extraordinarily expensive. Novel idea, but probably one that belongs in the Formula One arena, not the consumer sports coupe/sedan market.
Old Feb 3, 2003 | 09:34 PM
This project is directed towards the consumer market, not F1.
Whenever a part is made in large quatity, costs come down.
Old Feb 4, 2003 | 12:55 PM
no diagrams or pics of the engine
Old Feb 4, 2003 | 02:17 PM
wakeech's Avatar
mostly harmless
it's true that when supply increases, price drops as cost per unit decreases (to a point) but there has to be demand enough to clear the market at a price where the company will still profit, right??
that's a "maybe someday" kind of idea... although ceramics are light, strong, and resistant to the effects of heat, they're also extremely brittle... i could see a rotor (but not the housings) being made largely out of ceramic components, and there are already heavy-duty racing ceramic seals (which happen to eat perhipheral housings for breakfast, but that's another story), but metals are still much cheaper (higher profit) and better suited to most applications in engines.
Old Feb 5, 2003 | 04:46 AM
Buger's Avatar
RE member
The Mazda LeMans winner wasn't a production car yet it had ceramic apex seals and a ceramic-metal coating on the inside of it's rotary.
The Mazda Hydrogen prototypes weren't production cars yet they had ceramic apex seals and a ceramic-metal coating on the insides of their rotaries.
It is widely known that economies of scale can bring costs down? Stating that does not change the fact that a mass production ceramic component will still be MUCH more expensive than a mass production iron or aluminum component.
Old Feb 6, 2003 | 09:39 PM
Ceramic materials' unique properties are attractive to engine designers. An alternative to a 100% ceramic engine is ceramic coated aluminum engine.
Please refer to "Engine Coating" thread for more information.
Old Feb 6, 2003 | 09:44 PM
Buger's Avatar
RE member
Of course they are but this is not new information. If the costs were not so much higher, Mazda would have used them for their production rotaries. Refer to my previous posts from months ago hoping for such a thing.
The engine coating thread also does not have any new information for me to refer to?
Old Feb 12, 2003 | 02:13 PM
amgtortoise's Avatar
Like you have said so, ceramic apex seals offer all the beautiful properties of design & racing properties. But now, Mazda will not use this in production due to cost? Well, in a way it's sort of true, but many consumers don't see the cons of using ceramic apex seals. If 1 ceramic apex seal where to fail, it'll really get ugly since YOUR entire rotary engine just became a pile of garbage (you can ask the experts that have used them.) And, thus the liability cost of Mazda WARRANTY will be greater, cos now they have to replace you an entire engine.
I think IMHO that using carbon seals, will be better for performance & if they where to fail, damage will not be as much like the ceramic ones.
Old Feb 24, 2007 | 06:41 PM
DarkBrew's Avatar
Extraordinary Engineering
I know that I'm reviving an old thread but I had to prove that I searched before posting this link.
http://ceramicrotaryengines.com/
Making An All-Ceramic Wankel Engine - Progress
The image opposite is a photo of a small Wankel Rotor we ordered to specification. It is made out of CeTZP (zirconia) ceramic. The ceramic manufacturer shaped the CeTZP rotor in the green (soft) state and was subsequently sintered (in a furnace).
The combustion chambers on the rotor faces and the slots at the apex where the tip seals are to be located have yet to be machined. It is likely that this will be done in the hardened state to ensure that tight tolerances will be met. The gear will be made out of steel and fitted into the central recesses. The low thermal conductivity of the CeTZP ceramic should ensure that the steel gearing is kept from overheating.
We are considering making the Wankel housing out of CeTZP ceramic as well. This should ensure that the heat generated during the combustion of fuel will be retained within the walls of the combustion chamber. A CeTZP ceramic Wankel engine should not require liquid cooling.
Adequate sealing at high temperatures is clearly a major issue. Lubrication using liquids is not possible at high temperatures (> 600 C). It is likely that solid lubricants have to be used. A soft metal (e.g. gold) coating on the inner surface of the ceramic housing with nickel-based apex seals, is one choice. Another choice is to invoke choke flow by introducing turbulence at the tips of the apex seals, but studies of this effect is limited and applying this effect could prove impracticable or the sealing could be inadequate.
and as a bonus
a silicon MEMS micro rotary engine - They want to produce ~30mW at 40,000 RPM
Attached Thumbnails Ceramic Rotary Engine-micro-rotary.jpg   Ceramic Rotary Engine-micro-rotary-graph.jpg
Old Feb 25, 2007 | 10:31 AM
DarkBrew's Avatar
What? No comments?
I added some pictures
Old Feb 25, 2007 | 10:44 AM
deadphoenix52's Avatar
meh.
what is the weight of the zirconia ceramic compared to the steel rotors and housings we have now? it seems like it would be heavier, since ceramic is pretty heavy stuff.
Old Feb 25, 2007 | 05:01 PM
dillsrotary's Avatar
jersey fresh
wow, novel idea. I have little experience in ceramic engineering, but some questions i'd have would be heat transfer and of course weight. Also durability compared to iron.
Old Feb 25, 2007 | 05:06 PM
mysql101's Avatar
niiiiice
Old Mar 31, 2007 | 08:54 PM
rotary crazy's Avatar
intresting.......... I have to do some reading
Old Aug 23, 2007 | 01:16 AM
DOMINION's Avatar
I don't buy Kool-Aid
http://jhbperformance.com/
http://jhbperformance.com/services.php
Old Aug 23, 2007 | 01:26 AM
chickenwafer's Avatar
Nope
sounds cool....
Old Aug 23, 2007 | 07:15 AM
I want a 11:1 compression NA 20b!
Old Aug 23, 2007 | 08:12 AM
jird20's Avatar
Mad for a Furai
Very interesting products. They do look really functional and promissing.
Has anyone tried those?
Cheers
jird20
Old Feb 28, 2010 | 12:20 AM
sheik480's Avatar
Sorry to practice my necromancy, but isn't heat loss through the large surface area combustion chamber one of the biggest problems with wankels? If you could create a housing and rotor that would minimize heat transfer and that could stand the heat, wouldn't it go a long way to help with this problem?
Old Feb 28, 2010 | 03:25 AM
PhillipM's Avatar
Cheers
jird20
Yes, I've bolted 100,000 of them together, but I put them in my pocket and they fell through the hole
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Sifu
Aug 30, 2015 10:51 PM
cschoeps
Aug 6, 2015 12:44 PM
vssystemluba
Jul 19, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
