DIY: Noise Insulation for the RE Short Ram Intake
Old Mar 6, 2004 | 01:33 PM
Omicron's Avatar
I LOVE my Rotary Extreme short ram intake except for one thing: It's LOUD as HELL! When I get on the gas, after about 6000 RPM, its so loud that the entire dash and windwhield vibrates. This got so tiresome that I decided to see if I insulate it.
The stuff I got came from Home Depot, and I found it back by the insulation. Sorry I can't recall the name right now, but it's pretty easy to spot... it looks like a gigantic roll of puffy aluminum foil... and it is, after a fashion.
It's actually two really thick pieces of foil-mylar-like stuff, very strong. Sandwiched between the mylar/foil stuff is what looks like clear bubble wrap, but it's actually stronger and more heat resistant.
So I bought this stuff (it was like $10) and some spray adhesive. After I got it home, I cut a piece and went after it with a heat gun. The "bubble wrap" like stuff inside did eventually melt, but not until it got really hot. Much hotter than the heat shields of my intake ever get.
So, I took out both heat shields, cut a piece to fit on the inside of the side and back covers, sprayed them with spray adhesive, and fitted the insulation stuff to it. When the intake is reassembled, it is completely invisible... and even when you've got the top shield open, it still looks pretty good.
I would say this has made a 50% reduction in the noise of the Rotary Extreme short ram intake. It's still loud at WOT, but not nearly as obnoxious as it was before. I'm still a little concerned about it melting, but so far I've got 500 miles on it and have had no hint that it will.
So, without further ado, here's what I bought:
Attached Thumbnails DIY: Noise Insulation for the RE Short Ram Intake-p3060009a.jpg
Old Mar 6, 2004 | 01:35 PM
Omicron's Avatar
Now remove both heat shields, cut the insulation to fit, and spray a layer of spray adhesive (also available at Home Depot) on the inside. Fit the insulation immediately, the adhesive drys pretty quickly.
Here's a shot of the back shield:
Attached Thumbnails DIY: Noise Insulation for the RE Short Ram Intake-p3060005a.jpg
Old Mar 6, 2004 | 01:36 PM
Omicron's Avatar
Do the same thing on the top cover. Here's a shot of what it looks like (open):
Attached Thumbnails DIY: Noise Insulation for the RE Short Ram Intake-p3060007.jpg
Old Mar 6, 2004 | 01:37 PM
Omicron's Avatar
And finally, reinstall everything. Invisible... and boy, what a nice sound reduction! :D
Attached Thumbnails DIY: Noise Insulation for the RE Short Ram Intake-p3060003.jpg
Old Mar 9, 2004 | 03:38 PM
lugerxu's Avatar
That's the dumbest thing I think I've ever seen. You engine bay looks like crap. I'll give you a call next time I'm cooking baked potatos.
Old Mar 9, 2004 | 03:46 PM
Kain's Avatar
Human Being
baked potatos??? I think it looks fine!, it is not like the cover is off all the time
brothervoodoo's Avatar
RainMan is Back
Damn dude, why don't you chill out.
Old Mar 9, 2004 | 05:12 PM
cgrx's Avatar
DRIVEN
Thanks for the write up !!!!!!!!!!!!!!
Old Mar 9, 2004 | 05:28 PM
rotarygod's Avatar
Um, hi welcome to the forum. You can leave now! You sound like some ricer that believes in form over function. You were also dumb enough to insult a moderator here, and a damn cool one at that!
Old Mar 9, 2004 | 05:45 PM
310Guy's Avatar
4AT poor mileage king
Please, that troll (lugerxu) only has 8 posts...
Old Mar 10, 2004 | 08:35 AM
XeRo's Avatar
Normality is Obscene
So that actually worked out well for you Omi? I'm looking at this intake as well as SR Motorsports package deal...leaning more towards RE but don't want to have to scream when talking to passengers...
Old Mar 10, 2004 | 09:40 AM
Omicron's Avatar
Yes, it worked out excellently. Huge difference. It's no louder than stock at most throttle positions... it's only when I really get on it that it howls. And that's ok. :D
Old Mar 10, 2004 | 10:46 AM
Parmer8's Avatar
Don't you just love Home Depot!! They have everything you need--for your home and auto.
Old Mar 10, 2004 | 11:00 AM
Spin9k's Avatar
Momentum Keeps Me Going
With the covers and all, do you get the hesitation some have observed at certain RPMs?
Nice to see someone has solved the noise 'problem', for the most part.
Old Mar 10, 2004 | 11:04 AM
Omicron's Avatar
Yes I do. The only thing they need is the equivilent stock of a good metal shop. Oh, and maybe a bar. :D
Old Mar 10, 2004 | 11:08 AM
Omicron's Avatar
I note a hesitation at around 4500 RPM, but only when the engine is cold. I'm pretty sure it's one of the intake runner valves opening. Once the car warms up there is no significant hesitation anywhere in the rev band. I can still feel the intake runners opening, but they seem to do so faster and it's more of a blip than a hesitation.
Old Mar 10, 2004 | 10:59 PM
rudy8's Avatar
yes, i have the RE too. I insulated the inside of the top cover as well with a similar type of insul., and it cut the noise down significantly...its to the point that i enjoy the sound on daily drive...mostly normal with a nice muffled howl. it does get pretty loud at WOT. i may do the inside of the box too just to see.
I MOUNTED THE AIR FLOW METER WITH THE INTAKE TUBE TURNED 90 DEGREES TO THE DRIVERS SIDE (SO THE AIR FLOW METER WAS FACING THE L. FRONT WHEEL WELL...HAD TERRIBLE HESITATION, UNTIL I MOUNTED IT FACING THE SKY AS DIRECTIONS SAID. NOW, NO REAL HESITAION ...JUST LIKE OMICRON SAID. WORTH MONEY FOR THE SOUND ALONE.
also, everyone says RE is great and typhoon is trouble...worth listening to feedback.
Old Mar 12, 2004 | 09:52 PM
Cormath's Avatar
I do not yet own a 8. I was just skimming forums considering trading in my 94 firebird for a newer vehicle. After reading this thread I decided to sign-up just to post here.
Though the insulation you are using is a cheap fix, you might consider ordering some actual sound damping / insulation material. Knowing the engine compartment has heat considerations, try some that is also rated for heat.
The following I would think would work wonders for you. You could also consider the sides of the enclosure and what you can cover.
MYLAR®-FACED FOAM SOUND/HEAT INSULATION WITH VINYL LINING
Protects against noise, vibration, heat and cold.
$32.99 - $66.99
Permanent noise/temperature insulation ideal for use in engine compartment, hood, trunk and fender. Great under mats and floorboards. Acoustical-quality foam reduces airborne noise and noise from engine by absorbing vibration. Aluminized 1/2-mil. facing is attractive and easy to clean. Reflects heat and prevents absorption of dirt, fuel, oil, water, etc. Installs easily with contact adhesive (sold separately). Trims with scissors or knife for perfect fit. Instructions included.
Old Mar 13, 2004 | 12:21 AM
Omicron's Avatar
Hmmm, not bad. The stuff I picked out was mostly because of convienance... your selection looks better. Thanks!
Old Mar 16, 2004 | 05:18 PM
KiyoKix's Avatar
Very nicely done man. Brings ideas to my head now ...
Old Mar 16, 2004 | 06:50 PM
Omicron's Avatar
...of baking potatoes, perhaps? :D
LOL
Old Mar 17, 2004 | 02:15 PM
skuzbucket's Avatar
Dynamat
Ill post pics soon...
Old Mar 17, 2004 | 02:31 PM
guy321's Avatar
Humpin legs and takin nam
Hooking the vaccum tube for variable intake back up helps with the noise too.
Old Mar 17, 2004 | 03:51 PM
KiyoKix's Avatar
YUMMY POTATOES!
Old Dec 5, 2005 | 05:06 PM
Terrance26's Avatar
8 all the way
I have a typhoon short ram intake and I like the sound that it makes. But I guess whatever you like. Good idea though.
