Vendor Classifieds For our approved Vendors to post their for sale threads
BC racing coilovers @ Import Image Racing!! **ASK ABOUT EXTREME DROP KIT*************
Old Aug 17, 2011 | 10:57 AM
ImportImage's Avatar
Former Sponsor
Thumbs up BC racing coilovers @ Import Image Racing!! **ASK ABOUT EXTREME DROP KIT*************
denniss15.gif?t=1308794533
CALL 941-257-9618 and mention BILLY to receive special pricing ON RX8CLUB!!!!!
**Remember with Import Image you make YOUR OWN package deal! The more you buy the even great your discount gets **
rx8bc.jpg?t=1313692686
rx8bcracing.jpg?t=1313692760
bcinner.jpg?t=1313692796
We are the #1 Vendor in the nation for BC Racing coilovers!
BC Racing BR series Coilovers $995 Shipped!! Free Custom Spring Rates as well!!
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment ***** for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
BC Racing RAM type (Inverted) $1225 Shipped!!!
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series $1850 shipped!!
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
Disclaimer- Ad specials not valid on website, only valid by calling 804-690-2452 or 239-540-6385 visa/mc or paypal/googlecheckout.com shipped pricing refers to the 48 states. If you send a payment and live in FL and do not add 6% sales tax, your item will not ship. All returns subject to 35% restocking fee so make sure you want the part before you buy it! if received after 7 days, store credit will be given. after 2 weeks, returns will not be accepted. price subject to change due to manufacturer changing prices.
Questions: Billy 941-257-9618
(email)billy@importimageracing.com
AIM- importimagebilly
Old Aug 18, 2011 | 09:25 AM
Former Sponsor
Thursday Bump!
Regards,
Billy@importimageracing.com
AIM: ImportImageBilly
www.importimageracing.com
Direct Line: 804-690-2452
Shop Line: 239-540-6385
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
Old Aug 18, 2011 | 09:34 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
you dont have any pics of an 8 with your product. ill help you out here. send me your coilovers and ill replace my koni yellows and tien stechs with your stuff. then ill take pics of my car and send them to you this way others can see how they look/work on an 8
Old Aug 18, 2011 | 01:41 PM
Former Sponsor
Updated!
Old Aug 18, 2011 | 02:47 PM
bose's Avatar
Reginald P. Billingsly
What's different about the extreme drop package?
Old Aug 18, 2011 | 04:04 PM
Former Sponsor
Some cars needs either shorter springs and or struts, in this case you would need shorter struts.
Old Aug 18, 2011 | 04:37 PM
bose's Avatar
What range of adjustability does the regular br series have? How much lower can you go with the extreme kit? How much more would it cost?
The rears in the picture looks like there isn't much room to go lower.
Old Aug 19, 2011 | 10:02 AM
Former Sponsor
Extreme low kit is no extra cost. Like i said they would use shorter cartridges!
Friday Bump!
Regards,
Old Aug 22, 2011 | 02:02 PM
Former Sponsor
Monday Bump!
Regards,
Old Aug 23, 2011 | 01:16 PM
Former Sponsor
Tuesday Bump!
Regards,
Old Aug 24, 2011 | 10:02 AM
Former Sponsor
Wednesday Bump!
Regards,
Old Aug 25, 2011 | 03:59 PM
Former Sponsor
Thursday bump!
Regards,
Old Aug 26, 2011 | 01:55 PM
Former Sponsor
Friday Bump!!
Regards,
Old Aug 29, 2011 | 09:47 AM
Former Sponsor
Monday Bump!
Regards,
Old Aug 30, 2011 | 01:08 PM
Former Sponsor
Tuesday Bump!
Regards,
Old Sep 5, 2011 | 10:26 AM
Former Sponsor
Happy Labor Day, we hope everyone enjoys their day off!
Regards,
Old Sep 7, 2011 | 03:45 PM
Former Sponsor
Wednesday Bump!
Regards,
Old Sep 12, 2011 | 12:56 PM
Former Sponsor
Monday BUMP!
Regards,
Old Sep 12, 2011 | 01:03 PM
Former Sponsor
Monday BUMP!
Regards,
Old Sep 14, 2011 | 01:16 PM
Former Sponsor
It's Wednesday! Don't forget this week only use Coupon Code: NEWSLETTER on your website for 5% off!
Regards,
www.facebook.com/officialimportimageracing
Old Sep 15, 2011 | 10:55 AM
Former Sponsor
Thursday Bump! Don't forget this week only use Coupon Code: NEWSLETTER on your website for 5% off!
Be sure check out our facebook page as well!
Regards,
Old Sep 16, 2011 | 04:09 PM
Former Sponsor
Finally Friday!!!
Regards,
Old Sep 26, 2011 | 10:50 AM
Former Sponsor
I'm back!
Want to make a combo deal? NO PROBLEM let us know what you need
Regards,
Old Sep 27, 2011 | 07:55 PM
Former Sponsor
Can you PM me next time so i don't miss it?
I'll be in and out of the office today!
Shoot us a PM and we'll get back to you asap
Not sure if we carry something?
Just shoot us a PM and we'll take care of you!
Regards,
Old Sep 28, 2011 | 09:08 PM
Former Sponsor
Wednesday bump
Regards,
