Cheesy Question
Old Jan 27, 2003 | 01:02 PM
Mazda man's Avatar
Endangered Species
Cheesy Question
Sorry for the noobie question but what is the mathematical name( if there is one) for the rotor? Fat triangle? Puffy triangle?
Old Jan 27, 2003 | 01:16 PM
KKMmaniac's Avatar
VW coulda had it...
Good question! I think the path the rotor describes is called a trochoid, but I don't know about the rotor shape itself. Obese triangle?!
Old Jan 27, 2003 | 01:59 PM
Buger's Avatar
RE member
Hmm... convex faced triangle maybe? The compression ratio will change with the convexity of the triangle faces but the displacement will not. Similarly, the volume of the recesses or "bathtubs" on the rotor faces will change the compression ratio but not the displacement.
Old Jan 27, 2003 | 02:28 PM
eccles's Avatar
Prodigal Wankler
I'm sure there is a name for it, but it escapes me. Somewhere at home I have a reprint of the technical paper on the rotary engine that Kenichi Yamamoto presented to the SAE all those years ago. I'll see if I can dig it up.
Old Jan 27, 2003 | 04:08 PM
Mazda man's Avatar
Endangered Species
Thanks very much you guys!
Old Jan 27, 2003 | 05:46 PM
B-Nez's Avatar
I thought it was epitrochoid...that's what I've always called it
Old Jan 27, 2003 | 06:04 PM
eccles's Avatar
Prodigal Wankler
I believe you're correct. For more information that you probably wanted, look here.
But that's the shape of the rotor housing, not the rotor itself, which was the original question.
Old Jan 27, 2003 | 06:22 PM
B-Nez's Avatar
Damn, guess I had it backwards...oops.
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
