Driver Side Door: Routing RF Spkr Wire
Old Mar 1, 2004 | 07:41 PM
CactusGeorge's Avatar
Question Driver Side Door: Routing RF Spkr Wire
I was able to route some Rockford Fosgate Riot wire through the white plastic connector that leads from the passenger door into the car cabin.
For the driver side connector, however, I'm not able to find an opening in the white connector that will accommodate the speaker wire.
Has anyone successfully threaded a new wire through the driver side channel?
If I had a right angle drill that could work in a tight space, drilling a hole through the connector, but somehow I think that install shops have a better solution...)
Old Mar 2, 2004 | 12:29 AM
Tamas's Avatar
Registered Lunatic
Depending on the space and the angle, you might be able to drill such a hole... there are power drills (hand tools) that use a flexible drive so you can drill a hole in such tight locations.
Old Mar 2, 2004 | 09:21 AM
Picture of Door Connector
Tamas: thank you for the suggestion--I'll look into flexible drills (maybe Home Depot will have something...)
I've posted a picture of the connector at the Driver side door. There is only about a 1 1/2" clearance to work in--very awkward!
Old Mar 2, 2004 | 09:23 AM
8 Guage Green Wire
Oh yeah, the 8 guage green wire shown in the picture is what I use to pull the Rockford speaker wire back through the harness, so that needs to get fed through the connector...
Old Mar 2, 2004 | 03:39 PM
Lightbulb Solution for Routing Wire
I popped out the connector and cut the channel tab with a utility knife, then routed the green feed-wire
seb16
Sep 15, 2016 12:20 PM
vapor2
Oct 8, 2015 02:08 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
SayDfuse
Aug 3, 2015 10:41 PM
MarkX
Jul 31, 2015 07:50 AM
