Mazda RX-8 'M-Tips' - Service Techs
Old Jul 7, 2011 | 12:42 AM
ASH8's Avatar
Super Moderator
Here is a list of Mazda's (NA) M-Tips pertaining to the RX-8.
These are "tips" concerning 'issues or problems' for Mazda Dealer Technicians.
All RX-8 model years and series...please note the Model Year in reference to your car.
They may give you some help and advice in rectifying a Technical issue you may have or are experiencing.
Note: There is a possibility an 'issue' has already been resolved by your Mazda Dealer some time ago.
A -
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 12:43 AM
ASH8's Avatar
Super Moderator
a - b
ASH8's Avatar
Super Moderator
b - c
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 12:44 AM
ASH8's Avatar
Super Moderator
c - e
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
ASH8's Avatar
Super Moderator
e -
Note: ''Engine Stalls After Replacement'' has been updated to include 2009-2011 Series II's, in post #16...please not the errors in it for S2's.
Old Jul 7, 2011 | 12:45 AM
ASH8's Avatar
Super Moderator
e - h
ASH8's Avatar
Super Moderator
i - l
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 12:46 AM
ASH8's Avatar
Super Moderator
l - m
File Type: pdf
File Type: pdf
ASH8's Avatar
Super Moderator
m - n
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 12:47 AM
ASH8's Avatar
Super Moderator
n - p
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 12:48 AM
ASH8's Avatar
Super Moderator
P - r
ASH8's Avatar
Super Moderator
R - s
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 12:49 AM
ASH8's Avatar
Super Moderator
s -
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
ASH8's Avatar
Super Moderator
t - w
Old Jul 7, 2011 | 12:50 AM
ASH8's Avatar
Super Moderator
Remote Keyless entry system will not unlock doors
If you encounter a customer concern regarding doors not
unlocking when using the Remote Keyless Entry System, check
for possible installation of aftermarket LED light bulbs. These
bulbs may produce electrical noise that may interfere with the
operation of the Remote Keyless Entry System.
If you determine the Remote Keyless Entry System door unlock
malfunction is caused by an aftermarket accessory, inform the
customer and do not attempt any repairs to the vehicle.
ASH8's Avatar
Super Moderator
2004-2011 Engine Stalls After Engine Replacement
PDF CORRECTION WARNING..
I did not want to post this 'updated M-Tip' as the INJECTOR Colors information in it for Series II Engines is WRONG.....(and yes attempts have been made to MNAO over the past 10 months to have it rectified...all on deaf ears).
PRIMARY..........GREEN.........#N3R1-13-250......NOT RED as in this M-Tip
SECONDARY....Dark RED......#N3R2-13-250......NOT BLUE as in this M-Tip
For ALL Series II 6 Port Engines...
2 X PRIMARY Green Injectors install directly into the intermediate Iron Housing.
2 X SECONDARY Dark Red Injectors install into the LIM
Old Jul 7, 2011 | 12:51 AM
ASH8's Avatar
Super Moderator
New Tips for late 2012....
ASH8's Avatar
Super Moderator
New for 2012...
Old Jul 7, 2011 | 12:52 AM
ASH8's Avatar
Super Moderator
Intermittent 'Idle Dip or Wander' during extended idle for ALL Series RX-8..it is in your Air Filter Box!
File Type: pdf
File Type: pdf
Old Jul 7, 2011 | 01:10 AM
MazdaManiac's Avatar
"Clicking Sound While Turning" - 108 ft/lbs of lugnut torque?!? Holy crap!
Old Jul 7, 2011 | 09:39 AM
alnielsen's Avatar
I noticed that too. That's a big torque number for wheels.
Old Jul 7, 2011 | 09:46 AM
Now this should be stickied. Good stuff.
Old Jul 7, 2011 | 09:48 AM
DarkBrew's Avatar
Extraordinary Engineering
Good info! Thanks
Old Jul 7, 2011 | 09:51 AM
alnielsen's Avatar
Already done.
Old Jul 7, 2011 | 10:38 AM
bse50's Avatar
#50
Extemely helpful! Thank you Ash
