Lifting the rear?
Old Feb 27, 2004 | 08:12 PM
winter's Avatar
Lifting the rear?
Where the heck are you supposed to lift the rear of the car from? Looked in the manual, only thing I can find is the chassis rails. I'm tempted to use the rear diff, but kinda skeptical. I need both wheels up (installing an exhaust). What points have other people used?
Old Feb 27, 2004 | 08:21 PM
Gyro's Avatar
Rotary Abuser
there is a support brace the attaches to the underside with a knuckle. Its a very strong point, and can be found just before the rear wheel opening.
I too am reluctant to use the bottom of the rocker panels.
Old Feb 27, 2004 | 08:43 PM
BoxerGT2.5's Avatar
Get a pair of wheel ramps. Did wonders when I installed the Borla.
Old Feb 27, 2004 | 10:00 PM
winter's Avatar
Picked up a set of low-rise ramps.
Old Feb 28, 2004 | 01:31 AM
Gord96BRG's Avatar
The differential is the suggested jack point for the Miata. I see no reason why it couldn't also be used for the RX-8. In fact, when I changed the trans and diff fluid on my 8, I did use the diff for the floor jack to lift it up (held it up with jack stands under the side sill jack points).
Regards,
Gordon
Old Feb 28, 2004 | 01:57 AM
winter's Avatar
Ramp were $20 at Kragen. Well worth it, imho. Glad they finally had low-rise ramps, my old ramps were only good for my tundra. Supra, miata, & rx8 won't clear 'em.
tjohnmeyer
Sep 28, 2017 05:03 PM
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
