w00t, rx8store.com exhaust just arrived.
Old Feb 27, 2004 | 12:02 PM
winter's Avatar
Will put it on later today. Think there's any harm in firing it up without an exhaust? I'd love to get a sound clip of the rx8 with nothing behind the cat.
Old Feb 27, 2004 | 12:20 PM
XeRo's Avatar
Normality is Obscene
get some ear plugs...just incase you can't hear now...Y O U S H O U L D H A V E U S E D E A R P L U G S!!!
Old Feb 27, 2004 | 01:01 PM
jsplit's Avatar
Yeah that will be louder than all hell.
Seriously, wear something to protect your ears...
Old Feb 27, 2004 | 01:05 PM
Xavier296's Avatar
Always tinkering
Could shoot some flames if you are not careful, and also will probably trip a check engine light because a fresh air supply will be so close to the 2nd O2 sensor. I wouldn't do it, but if you do, try to be outside. Even a 1.5 liter spitfire motor sounds like a canon going off with only a header.
Old Feb 27, 2004 | 01:39 PM
Sue Esponte's Avatar
Grand Poobah
It would sound like a car without an exhaust....horrible.
I'd love to hear a clip of the new exhaust once you get it though!
Enjoy!!!! :D
-Eric
Old Feb 27, 2004 | 04:11 PM
Velocity-8's Avatar
Whuumpha!!
I ran my Mini Cooper with exhaust removed from the cat back and it was L O U D! We ran it on a Dynojet like that and it put out the lowest HP of all the dyno runs.
Old Feb 27, 2004 | 04:32 PM
Omicron's Avatar
Most cars need a little back pressure.
Old Feb 27, 2004 | 04:35 PM
winter's Avatar
Enjoy!!!! :D
-Eric
I'll definitely be posting clips of the new exhaust. And you should quality your statement... it'll sound like a rotary without an exhaust, which is 10x worse than an uncorked piston engine.
Old Feb 27, 2004 | 11:36 PM
winter's Avatar
Welp, bad news. I am unimpressed by the rx8store exhaust. Build quality seemed good, but they didn't include bolts to attach the mufflers to the pipe. Managed to scrounge some up, went to bolt the pipe up onto the cat, and it didn't fit. The flanges were off by at least a half inch off of the cat's studs, and the pipe was too big for the cat outlet. Perhaps this particular unit was designed with a 3" mid-pipe in mind?
At any rate, I'm going to go ahead and send the rx8store.com exhaust back and order a B&B. It seemed like a very nice exhaust, I'm just sorry I couldn't get it bolted up to the car to try it out.
Old Feb 28, 2004 | 02:00 AM
Psychofox's Avatar
我愛台妹,台妹愛我
sorry to hear that, hope B&B exhaust will work out for you.
maybe you should consider HKS exhaust, i have it the finish and fitment are really nice
Old Feb 28, 2004 | 02:14 AM
winter's Avatar
The HKS appeals to me, but the price doesn't. Too many other projects to put money into.
Old Feb 28, 2004 | 07:32 AM
Velocity-8's Avatar
Whuumpha!!
What about the Borla?
Old Feb 28, 2004 | 07:47 AM
cgrx's Avatar
DRIVEN
The Borla is sweet !
Old Feb 28, 2004 | 07:49 AM
cgrx's Avatar
DRIVEN
If you are ever up in Thousand Oaks they have a Borla exhaust system on a red RX-8 you can drive and check out.
Old Feb 28, 2004 | 09:25 AM
Jason's Avatar
RX7store.net
You are not bolting the exhaust up correctly if its not fitting. I would mount the pipe on the cat first without bolting it to the mufflers. Then mount the mufflers on the hangers and then bolt the mufflers to the pipe. If you do it any other way its going to be very hard to install. You may also need to shift the exhaust on the hangers to get it to lineup correctly. There should be a small bag in the box with a gasket and bolts.
I have had one other person complain it didnt fit and after mounting it like I suggested he didnt have any problems.
The exhaust is made from a jig and almost impossible for the piping to be off. It always possible it was bent in shipping.
Jason
Old Feb 28, 2004 | 11:18 AM
winter's Avatar
This is how I was doing it... struggled with it for quite awhile, but it just wouldn't line up with the studs (flange on the rx8store was too large). I'll give it one more go, and take pics of both the stock unit and the rx8store for comparison.
Old Feb 28, 2004 | 12:20 PM
Jason's Avatar
RX7store.net
Yea if you could get a couple of pics that would be great. Send them to jbaughman@ameritech.net
Jason
Old Feb 28, 2004 | 04:50 PM
Overport's Avatar
Overport
wish i could be there....its gonna be nasty and loud!:D
Old Feb 29, 2004 | 10:14 AM
hac's Avatar
hac
Thanks for the advice Jason. I should be receiving my RX8 exhaust any day now.
Old Mar 8, 2004 | 04:38 PM
winter's Avatar
Gave it another go, it still didn't fit. Picked up a B&B, fit perfectly. I'll take comparison pics of the rx8store and the stock to show the difference in flange and pipe sizes.
Old Mar 8, 2004 | 04:45 PM
success07's Avatar
I'm Kind of a Big Deal
Winter - Why didn't you just get another exhaust from the RX8Store? You liked it enough to buy it the first time, right? Why so quickly to change? Not that your replacemant won't do the job but just curious.
Old Mar 9, 2004 | 01:06 AM
PhineasFellOff's Avatar
success07, are you suggesting Winter just didn't like the RX8 Store exhaust and made up a reason to return it for the B & B?
Old Mar 9, 2004 | 09:07 AM
success07's Avatar
PFO - No, not at all. I have the RX8Store exhaust and all is great. Several others have it and have had no problems. I was simply curious because if I like something enough to buy it and in turn something isn't right with it, I usually give it a second chance just for the purpose that it may just be a one time issue. I spend alot of time researching the things that I buy and should something like this come up, which it does on occasion, I allow myself to get one more for comparison. If that one has an issue than I know that it wasn't for me and then it's time to research a different product. No harm, no foul.
Old Mar 9, 2004 | 09:54 AM
Overport's Avatar
Overport
good luck
Old Mar 9, 2004 | 12:25 PM
winter's Avatar
Success07, I'd originally ordered a B&B from hopupracing, but after getting the runaround for a few weeks I cancelled that order and placed an order with rx8store, because they could ship an exhaust that day. After spending that night trying (and failing) to install the rx8store exhaust, I decided to take a close look at the other options. After viewing a B&B in person, I was very impressed by the fit and finish of it, and decided to order one (my mind was already pretty much made up, since it was the exhaust I'd originally wanted).
I held off on returning the rx8store until the B&B arrived, because I was curious to see if the fitment issue with the rx8store was my screw up (I'd feel like a jackass returning a perfectly good exhaust, and figured I'd sell the one I liked less on here). Tried the rx8store one more time for good measure, then tried the B&B. The B&B lined up perfectly with the flange studs on the cat, took about 20 minutes to install.
I'm very happy with my B&B exhaust, and am sure I would've been happy with the rx8store. Considering the large number of people here with rx8store exhausts, this one seems to be a fluke, and shouldn't reflect poorly on them.
Hunterkelley24
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
