Vendor Classifieds For our approved Vendors to post their for sale threads
TOKICO DSPECS + TEIN STECH or HTECH Combo! FREE extensions!!!
Old May 12, 2011 | 03:57 PM
THmotorsports.com's Avatar
Former Sponsor
Smile TOKICO DSPECS + TEIN STECH or HTECH Combo! FREE extensions!!!
Tokico Shock Kit - D-Spec Series DSP Kit
Product Description
Tokico’s D-Spec Series adjustable shock is a multi-use product that’s the result of sophisticated piston and valving design. In addition, it utilizes a unique variable-aperture bypass, which is controlled by an adjustable slide valve.
D-Spec (damping specific) adjustments change both rebound and compression damping simultaneously. Between maximum soft and hard settings, the D-Spec is infinitely adjustable.
Tokico D-Spec shocks and struts kits are sold in matched sets of four. Each set includes a manual explaining the adjustment process as well as covering suspension tuning tips.
TEIN Springs - STech Springs
Product Description
TEIN S.TECH Spring is an excellent step towards suspension tuning.
They offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty.
Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects.
Features
One year limited warranty
High-grade material adapted to improve guaranteed satisfaction
Rubber spring protector sheet to prevent noise (most applications)
Specs
Ride Height (F) -1.4in (-36mm)
Ride Height (R) -0.7in (-18mm)
Spring Rate (F) 207lbs/in (3.7kgf/mm)
Spring Rate (R) 145lbs/in (2.6kgf/mm)
TEIN Springs - HTech Springs
Product Description
High Tech is made from a new material called “Vanadium” which is much lighter then other spring and increases flexibility.
Features
All spring are designed specifically to fit each car for maximum performance
About a 1 inch drop for a more attractive appearance
Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet (available for most model)
Specs
Ride Height (F) -1in (-26mm)
Ride Height (R) -0.3in (-8mm)
Spring Rate (F) 179lbs/in (3.2kgf/mm)
Spring Rate (R) 129lbs/in (2.3kgf/mm)
FREE WITH COMBO!!!
DSpec Adjustment Extensions
***If you prefer different springs or different combinations let me know and I will make it happen!!!***
SUPER COMBO DEALS!!!
PM US OR CALL US FOR BEST PRICES AVAILABLE AND FOR ANY DESIRED COMBO DEALS!!!
Looking forward in hearing from you.
Thank you,
Adam
THMotorsports
800-959-0145
www.thmotorsports.com
adamk@thmotorsports.com
AIM = adamkthm
Old May 13, 2011 | 07:06 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
hey adam can you pm me a price on just the d-specs, i all ready have the springs
thanks jesse
Old May 13, 2011 | 07:07 AM
paimon.soror's Avatar
This was the combo I was planning to go on if I didn't get such a good deal on my Stance's! Awesome deal bump.
Old May 13, 2011 | 12:23 PM
RotaryMachineRx's Avatar
SPOOLN8
I wouldn't mind a price for just the Dspecs as well if possible.... Shipped to S7H 5B5, Canada. Would you recommend these over the KONI Sports (yellows)?
Old May 13, 2011 | 01:56 PM
Former Sponsor
thanks jesse
PMd ya guys on just the Dspecs!!!
they're going fast!!!
fo sho man!!! STANCE FTW!!
-Adam@THM
Old May 13, 2011 | 04:55 PM
Juansito's Avatar
Redlined
How much for dspecs and tein stechs? 10002
Old May 16, 2011 | 06:47 PM
Former Sponsor
PMd ya!
Old May 17, 2011 | 12:07 PM
slvrstreak's Avatar
Angler of the Year
D specs and S techs to 31014 please
Old May 17, 2011 | 03:14 PM
Former Sponsor
PMs sent!!!
LMK
Old May 17, 2011 | 08:31 PM
hookedonfonix's Avatar
D specs and S-Techs to 95818 please
Old May 18, 2011 | 12:42 AM
Rigoherrera's Avatar
d specs and stechs to 77044
Old May 18, 2011 | 11:23 AM
09Factor's Avatar
Original Turbo 'd Auto !!
FWIW to those intrested.
I have run this combo of S-Techs and D-Specs since early 2006 and have never regeted it. Nice setup for the 8!
Old May 18, 2011 | 11:30 AM
SPOOLN8
I'd like to see someone who as run the KONI's as well and get a comparison. They are cheaper but I'm thinking you get better quality with the Tokico's and having the adjusters for the rear so all 4 corners can be soften or hardened very simply is key...
Old May 18, 2011 | 02:08 PM
alexisonfire's Avatar
The autocross n00b
how much for the d specs and stechs to 07011?
Old May 18, 2011 | 03:22 PM
RX8jtm's Avatar
Can I get a price on the D specs and S techs to 32807 please. Thanks
Old May 18, 2011 | 04:31 PM
Former Sponsor
Smile
Indeed its a very nice setup on the 8....and you get a nice combo deal under $800 SHIPPED!!! + FREE rear extensions
KONIs will be a better shock for those more dedicated to autoxing, tracking and simply a more grip oriented setup. While the Dspecs will be a very good all around setup.
All in all both combos will yield awesome results over stock. If you guys want to get quoted on any other combos let me know and I will make it happen.
Thank you,
Adam K
THMotorsports
800-959-0145 ex2
AIM = adamkthm
Old May 18, 2011 | 04:57 PM
SpeeD_TeaSe's Avatar
Just the s-techs to K1C 2T4 , Canada thanks
Old May 18, 2011 | 06:20 PM
SPOOLN8
Thank you,
Adam K
THMotorsports
800-959-0145 ex2
AIM = adamkthm
Which one lowers the car more? I have S-Techs on stock struts right now and the rear end just seems like it needs to be a little bit lower (1/2" or so) to match the front.
hornbm's Avatar
dspecs plus stechs to 98056!
Old May 19, 2011 | 05:01 AM
goose guy's Avatar
dspecs + stechs to 96819. thx.
Old May 19, 2011 | 06:56 AM
Jtaylor3's Avatar
Price shipped to 44011 for both combos
Old May 20, 2011 | 01:49 PM
L8tr's Avatar
Still Zooming...
price for s tech combo to 98682?
Old May 20, 2011 | 04:18 PM
Former Sponsor
Check the first post for specs on the springs. Let me know if that works or if you want to look into other springs.
All PMs sent....LMK guys
-Adam
Old May 20, 2011 | 04:28 PM
Polish Person's Avatar
Effin' Awesome User
Combo with S.Techs to 23150. Thanks!
Old May 20, 2011 | 04:42 PM
Effin' Awesome User
Also, do you know if installation of the D-Spec's requires any modification in an S2? I know some shocks require the factory strut bar be cut.
