How to Remove Door Panel
Old Feb 24, 2004 | 05:44 PM
CactusGeorge's Avatar
Following are a couple of pictures to illustrate how to remove the front door panels.
Old Feb 24, 2004 | 05:46 PM
Front of Door Panel: Remove Screws
Three screws to remove.
Attached Thumbnails How to Remove Door Panel-frontdoorpanelinstalledscrewlocations.jpg
Old Feb 24, 2004 | 05:47 PM
Remove Panel Connectors
I put electrical tape on the Removal Tool to limit scraping on the door paint.
Attached Thumbnails How to Remove Door Panel-frontdoorpanelremovedpressconnectors.jpg
Old Feb 24, 2004 | 10:31 PM
DavisRx8's Avatar
Thanks for posting those pics! I've been having trouble getting the front door panels - it was that one screw under the side panel.
Old Feb 25, 2004 | 02:20 PM
Third Screw Location
Glad the pictures were a help!
Old Feb 26, 2004 | 12:39 AM
Parmer8's Avatar
CactusGeorge
On removing the panel to get to the third screw, does that panel pop off easily? Do you have to pry it off with a screw driver?
Old Feb 26, 2004 | 12:46 AM
adrian-1's Avatar
Ex- member.
Use a flathead screwdriver from the bottom. There's a tab on the top part that will break if you try to pop it from the top. See image.
Old Mar 3, 2005 | 08:26 AM
StphNieuw's Avatar
Excellent how to guys.
Old Mar 3, 2005 | 09:39 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Great info, lets see if we can get this moved the DIY forum.
Old Apr 28, 2005 | 05:44 PM
ddalrymple's Avatar
I must be missing something! Where are the pictures?
Old Apr 28, 2005 | 05:46 PM
TooBIG's Avatar
It looks like old posts get the picture links removed.
It's a board problem.
I am looking for these pics also..
Old Apr 28, 2005 | 06:12 PM
NVMYGT's Avatar
IM2BZ2P
me too...I want to insulate the doors this weekend.
Old Apr 29, 2005 | 08:07 AM
extremeconceptsandsound's Avatar
mike
i would also like to see them thanks
Old Apr 29, 2005 | 10:59 PM
Jabberwock's Avatar
Any update on this?
Old May 5, 2005 | 01:36 AM
rx-81688's Avatar
Can we have a look at those pic pleases. we miss out.lol we want our door panels off without breaking anything. Thax
Old May 6, 2005 | 02:05 AM
Jabberwock's Avatar
Old May 7, 2005 | 03:33 AM
mikeb's Avatar
100% Italian
how about removing the freestyle door?
Old May 8, 2005 | 01:30 PM
RXLogic's Avatar
Curves Ahead
No pictures, and I can only find two screws. There's one behond the door latch, and another behind the handle on the right. There's another place where there is somethinglike a screw above the handle, but I don;t think it is. I don;t see anything that looks like a side panel either. What am I missing?
Old May 8, 2005 | 02:42 PM
adrian-1's Avatar
Ex- member.
I may have the pics on my home PC, I'll update tonight.
Old May 8, 2005 | 10:08 PM
adrian-1's Avatar
Ex- member.
Front door
File Type: bmp
File Type: bmp
File Type: bmp
File Type: bmp
Old May 8, 2005 | 10:10 PM
adrian-1's Avatar
Ex- member.
rear door trim (remove in the order below)
File Type: bmp
File Type: bmp
File Type: bmp
Old May 9, 2005 | 05:25 PM
TooBIG's Avatar
Thanks Much !
Old May 9, 2005 | 05:52 PM
mikeb's Avatar
100% Italian
thank you
that helps alot
Old May 10, 2005 | 09:38 PM
RXLogic's Avatar
Curves Ahead
Thank you very much.
Old Oct 17, 2005 | 09:13 AM
Astral's Avatar
Purveyor of fine bass
when removing door
When removing the door, don't forget to disconnect:
* window controls
* lock controls
* red LED connector (above the door controls)
* remove the door courtesy light
