Feel of a Rotary Engine
Old Apr 18, 2002 | 11:13 AM
DANNER's Avatar
Question Feel of a Rotary Engine
I've heard a bunch of people say you have to feel a rotary engine to understand. I've never had the opportunity to drive an Rx7. So what's the big deal? Is there a noticable diffence between the feel of a piston engine vs. a rotary? How does it feel different?
The only thing I can think of is that most of power comes in a higher RPM right? But that's not really any different than a lot of 4 cyl VTEC/VVT engines.
Old Apr 18, 2002 | 01:37 PM
JGard18's Avatar
Something
from my experience... the Rotary doesn't vibrate as much, has a nicer sound, and has no torque.
Old Apr 18, 2002 | 06:43 PM
spwolf's Avatar
how do you mean it has no torque?
Old Apr 18, 2002 | 06:46 PM
TheOMan's Avatar
Question Sound
Speaking of sound...does anybody know of a site with samples of what a rotary engine sounds like? I've done some searches and visited the sites that came up in the results, but the samples I found weren't very good.
The sound of the engine is important to me when considering a car purchase, and I've been told rotaries have a very distinctive note that I'm curious to hear. Any suggestions of sites I could visit would be appreciated.
Old Apr 18, 2002 | 06:51 PM
Toadman's Avatar
Nomad Mod
There is no real powerband "hit"(turbos excluded). It spins like an electric motor to the structural limits of the rotors and housings themselves. The feel(vibration or lack of?) is similar to most modern V-6 engines, only it never falls off the powerband. As the rpm climb, the more efficient and more power it makes, with only 3 moving parts. It loves and lives to rev.
787b
This is the 1991 LeMans winning 4-rotor taking it easy at Laguna Seca.
Some Dyno-runs can be found here.
Old Apr 18, 2002 | 07:59 PM
DANNER's Avatar
Sounds cool. Almost like a motor cycle.
Old Apr 19, 2002 | 08:40 AM
JGard18's Avatar
Something
by no torque, I mean that there is little power when the engine is under 4,000 RPMs. The engine isn't highly responsive until the engine revs are up high... as opposed to my Impreza now, with a 2.5L boxer 4, the thing can be at 2,000RPMs, and have almost as much power as there is at 5,000RPMs
Old Apr 19, 2002 | 02:30 PM
ZoomZoom's Avatar
Drive it like U stole it!
I thought that the R&T article mentioned that 90% of maximum engine torque would be available at 3250 RPM. If that is the case, I do not see torque being an issue.
Old Apr 19, 2002 | 02:48 PM
JGard18's Avatar
Something
that may be true...but on my older RX-7, that sure wasn't the case.
Old Apr 19, 2002 | 04:05 PM
Maurice's Avatar
Hey Toadman
I'm trying to attach a file like you did for the sound and dyno tests, but can't figure out how to do it. I have an RX-7 dyno test that will blow you mind. Can I email it to you, and have you post it on the forum?
Old May 1, 2002 | 04:20 PM
fluxen's Avatar
That's because it's revving so high. Don't expect an RX-8 sound quite like that, though with an aftermarket exhaust, you can get close.
Old May 1, 2002 | 07:54 PM
rpm_pwr's Avatar
No it's not. The LeMans car - even in qualifying trim - had a max redline of about 7500rpm with a race redline of either 6750 or 7000 (cant remember) it did not rev high, I imagine because of ecc. shaft flex. It sounds cool because:
a) It's a 4 rotor
b) It's a PP
-pete
Old May 1, 2002 | 11:19 PM
Dazz's Avatar
This is taken from a very good article on the 787B here ...
http://dev.roadandtrack.com/images/r...mazda_787b.htm
"At Le Mans, an 8500-rpm limit was used during the race and up to 9000 rpm was allowed for qualifying"
There is some excellent technical information here for anyone interested in real details about the engine.
http://www.mymazdarotary.com/mazda_r...paper_html.htm
Old May 2, 2002 | 06:19 AM
FritzMan's Avatar
Feels is like a turbine. Although I've never personally felt an actual turbine, it's the first thought that crossed my mind when I drove on. Fairly vibration free with smooth power delivery.
Old May 2, 2002 | 12:30 PM
Grimace's Avatar
Certifiable car nut
Its true. Mazda has done a lot of work to increase the Renesis low-end torque to better suit the North American driving style.
Old May 2, 2002 | 12:37 PM
fluxen's Avatar
a) It's a 4 rotor
b) It's a PP
-pete
Well, it's 8500 - 9000 rpm, I stand corrected. Sorry about that, I just automatically think of race rotaries (13b) reving to 11k +, and failed to remember we're talking about the 26b here.
Old May 23, 2002 | 03:34 PM
Seanyb1's Avatar
Driving a Rotary is like nothing else. Smooth as ice the car just goes where you want it, hard to explain. Its like having a spaceship engine.
Old May 23, 2002 | 09:19 PM
eelkmoore's Avatar
Angry
it better have lots of torque...
Old May 24, 2002 | 12:45 AM
Jerome81's Avatar
I Am Rotary Powered
LOTS of torque? You might wanna look at a V8....
While this rotary promises to have good midrange punch, rotaries have never been what you would call "torquey."
Old May 24, 2002 | 10:03 AM
Grimace's Avatar
Certifiable car nut
Rotaries are revvers. If you want to short-shift it like a Mustang GT or something, you'll be disappointed with the performance. Torque is supposed to be around 155 ft lb., 90% available between 3000 rpm - redline.
Old May 24, 2002 | 05:03 PM
eelkmoore's Avatar
Unhappy
well now i look like a dumbass.
Old May 26, 2002 | 07:56 PM
rpm_pwr's Avatar
Ok. I can see that this is going to come up a lot. So I'm just going to cut-and-paste. If I have to use it too much I'll do up some pretty pictures/graphs to go with.
-pete
As probably the only person on the forum with a dual-axis accelerometer kicking around I think I should clear a few things up that some people (buger etc) have touched on:
1)
Your accelaration graph is *PROPORTIONAL* to your torque graph for in gear acceleration
2)
The proportionality constant is
= (tyre radius * gear reduction) / mass
3)
The important factor here is gear reduction (diff ratio * current gear ratio). In other words you can double your acceleration (wind resistance ignored) by doubling you diff ratio. But by doing this you can detract from the usability of the car by reducing the max speeds in each gear.
Now here is the important bit:
ENGINES WITH HIGHER OPERATING RANGES CAN USE HIGHER RATIO DIFFERENTIALS FOR THE SAME AMOUNT OF DRIVABILITY. THIS MULTIPLICATION EFFECT GIVES MORE GROSS TORQUE AT THE REAR WHEELS GIVING MORE ACCELERATION END OF STORY.
4)
Torque spread only affects how wide you can spread the gear ratios. It does not matter where in the RPM range the spread is because this can be traded with diff ratios rather it is the RPM range that affects how close you can make the ratios. So a car with power from 5000rpm to 8000rpm can have ratios just as wide as a car with power from 2500 to 5500 with the added advantage that it can run a higher diff ratio to increase acceleration.
5)
so say
car a makes 200lb.ft from 3000 to 6000 with a 4.11 rear (FD?)
car B makes 150lb.ft from 5500 to 8500 with a 5.82 rear (rx8?)
car a has 822rw lb.ft GROSS
car b has 873rw lb.ft GROSS
but here's the catch - both cars have identical speeds in each gear! It gets better the higher torque numbers give a higher top speed as well!
6)
With all this messing around with mulitpliers, dividers, NET torque gross torue isn't there an easier way? Yes. It's the often neglected POWER curve. Power at the flywheel = power at the wheels - gear losses. So you can simply overlay two RWHP graphs with shift points marked to figure out which will accelerate harder. It's a lot easier. That's why we can't bench race the rx-8 yet - because there is no power graph yet. Although if the torque spread stays that good then it will be ONLY the diff ratio stopping the rx-8 from being an FD rx-7 killer.
Old Jun 13, 2002 | 09:57 PM
meteoro's Avatar
The feel of a rotary is like no other. First there is no vibration, in my old 1st gen RX, when it was properly tuned, you could hardly tell when the engine was on. There is no vibration whatsoever. As far as torque, I never felt like it lacked it. By no means is it a big block V8 from Detroit, but it has enough. Also, Mazda always does a great job with the gearing.
I cannot wait to get one.....
Old Jun 21, 2002 | 08:24 PM
cOz's Avatar
cOz
uuuhhh what he said...
jj
We will just have to drive it.
Old Dec 19, 2007 | 12:59 PM
pfloydss's Avatar
This is an old thread that should start up again now that we all know what they feel like. I want to know your opinions on how they feel to you in your own words.
To me its like a Singer sewing machine.
