DIY: 3rd brake light RX-8 logo mod
Old Feb 17, 2004 | 08:20 PM
D MENAC 7's Avatar
Moderator with a mycocardium
DIY 3rd brake light RX-8 logo mod
I thought I would do a DIY for the 3rd brake light RX-8 logo and show a step by step instruction.
First, I needed a way to produce the RX-8 graphic to be used as a mask so that I didn't have to take the lengthy time to cut a mask with an Xacto knife. Because I work in education and multi media, I went with what I have on hand which is a transparency film which is printed on by a laser printer and is normaly used for graphics on an over head projector. After some trial and error as to what is the ideal size to be produced through the lens of tht third brake light I came up with an acceptable design.
I found two ways to mount the graphic masking.
One is behind the red lens which I like to refer to as a stealth mount. WIth this method you do not see the logo until the brakes are applied.
The second is the mounting of the graphic on the front side of the red lens and by this method, you see the red outline of the RX-8 logo even with the brake light not lit. I found this method to work best, imo.
Here is the finished look with the brake light applied using the second mehtod.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-final-shot-brake-light.jpg
Old Feb 17, 2004 | 08:22 PM
D MENAC 7's Avatar
Here is what the graphic printed out and cut to size looks like.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-transparency-graphic.jpg
Old Feb 17, 2004 | 08:25 PM
D MENAC 7's Avatar
I found to get a better masking that two of the graphics needed to be taped together with small pieces of clear tape.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-transparency-graphic-x-2.jpg
Old Feb 17, 2004 | 08:28 PM
D MENAC 7's Avatar
Here is how to disassemble the third brake light.
First, you need to remove all of the nylon screws holding up the trunk lid liner and then remove this liner from the lid.
Next you need to remove both mounting 10mm nuts and unplug the lamp socket and remove the entire third light assembly.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-third-brake-light-removal-correction.jpg
Old Feb 17, 2004 | 08:31 PM
D MENAC 7's Avatar
After you remove the third light assembly, you need to start disassembling the housing. First take out the two screws mounting the lamp housing.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-third-brake-light-disassymbly.jpg
Old Feb 17, 2004 | 08:37 PM
D MENAC 7's Avatar
Next there is a clamp that holds the rear red assembly in place. I also found on the other side two hinge type parts that hold this part onto the center red lens. After taking this all out, I eventually seperated the rear red assembly from the center red lens. To get to that point, it may be easier to remove the two red parts together by pusing in on the slot on both sides and sliding these out of the clear lens part of the assembly.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-remove-red-reflector-lens.jpg
Old Feb 17, 2004 | 08:40 PM
D MENAC 7's Avatar
After disassymbling all three parts here is what you have.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-third-brake-light-disassymbled.jpg
Old Feb 17, 2004 | 08:41 PM
flyboyindy's Avatar
Very nice D....now make me one! =)
Old Feb 17, 2004 | 08:43 PM
D MENAC 7's Avatar
Next you have to decide which placement to use to mount the RX-8 logo.
For the "stealth" method, you want to mount the graphic on the inside of the center red lens. To do this I used the same clear tape to afix this inside the lens.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-test-stealth-mounted.jpg
Old Feb 17, 2004 | 08:46 PM
D MENAC 7's Avatar
Next you need to reassemble the third brake light. This is a shot with the graphic in place behind the center red lens and the unit reassembled. Note, this was shot using flash photography and normally you would not see anything because it is dark in the area behind the red lens.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-test-stealth-unlit.jpg
Old Feb 17, 2004 | 08:48 PM
D MENAC 7's Avatar
Here is a shot with the lamp lit in the "stealth" mounting method.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-test-stealth-shot.jpg
Old Feb 17, 2004 | 08:49 PM
D MENAC 7's Avatar
The second mounting is done on the other side of the center red lens. Here is what it looks like mounted.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-non-stealth-mounting.jpg
Old Feb 17, 2004 | 08:51 PM
D MENAC 7's Avatar
Here is what it looks like after assembly. Here you see the logo in red unlit through the clear lens.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-non-stealth-unlit.jpg
Old Feb 17, 2004 | 08:52 PM
D MENAC 7's Avatar
And here is a shot of it lit for the test.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-non-stealth-test-lit.jpg
Old Feb 17, 2004 | 08:55 PM
D MENAC 7's Avatar
Finally, here is a shot of it at night. Rememberr, it's very difficult to take photos of light in the dark. It's hard not to over expose so, this photo cannot do it the best justice as the first in the light at the beginning of this thread.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-brake-light-lit.jpg
Old Feb 17, 2004 | 08:58 PM
93rdcurrent's Avatar
The Stickinator
Beautiful. Now I have to decide if I want stealth or not. Decisions... decisions...
Old Feb 17, 2004 | 08:59 PM
D MENAC 7's Avatar
I will be glad to provide more information if anyone cares to ask. If you PM me, I can let you know the availability of these logo maskings if you would not wish to go through the work of producing them. If you would like, I can send you a file with the logo graphic if you have the materials at hand and wish to do it yourself.
Old Feb 17, 2004 | 09:07 PM
Omicron's Avatar
A very, very nice DIY, D MENAC 7!!! Gonna sticky this for a while. :D
Old Feb 17, 2004 | 09:42 PM
D MENAC 7's Avatar
logo file
I hope this works, here is a copy of the graphic. It measures 6.513" wide by 1.556" tall. If you open it up in PS or another graphic program, you can size it to these dimensions and that should take care of it if it is not the exact size after saving the file.
Attached Thumbnails DIY: 3rd brake light RX-8 logo mod-rx-8-brake-logo.jpg
Old Feb 17, 2004 | 09:50 PM
D MENAC 7's Avatar
I am still developing one that will fit in the clear lens part of the third brake light and am thinking about doing it in the color of the car, that is still on the drawing board becasue it really has to be opaque from the back otherwise the masked area would be purple on a Winning Blue, orange on a Lightening Yellow, Black on a Black....that might just work on there....brown on a Nordic Green, dark red on a Silver and Gray and may not show up on the best of colors, Red on a Velocity Red.
There would have to be some printing method to print on clear film that would have a first layer of some dark opaque color and then a color on top of that to fully mask out all lighting where you wouldn't want it.
Old Feb 17, 2004 | 09:52 PM
D MENAC 7's Avatar
YEA, I made a sticky!!! Wait a sec....maybe that's not good!!:o Oh, you meant a sticky for the forum...that's better :p
Old Feb 17, 2004 | 11:15 PM
The Stickinator
Very funny... I may have an idea... uh no not about the sticky. If you could get two to line up you could just do one in black and then put the color of your choosing in front of it. If they lined up perfectly it would solve the transparent issue with the different colors.
Old Feb 18, 2004 | 12:38 AM
D MENAC 7's Avatar
Duh...why didn't I think of that??? Thanks! it's off to bed then off to the drawing board I go tomorrow.
Old Feb 22, 2004 | 07:04 AM
Genom's Avatar
Not so Super right now
Just a tip, most vynil printing shops will do that quite easy. I cheked locally and to do 2 layers of it in that shape and size was all of 10 bucks tops.
Old Feb 24, 2004 | 05:53 PM
RX8FanMan's Avatar
JRizzle
where can i get this again?
