DIY: How to flush your brake fluid?
Old Jan 17, 2011 | 05:21 PM
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-brake-bleeding-flushing-210519/
Old Jan 17, 2011 | 05:32 PM
invasion08's Avatar
You are way off. The brake fluid will not drain out by gravity.
1. Remove the bleeder cap from the brake caliper, and connect a vinyl tube to the bleeder screw.
2. Place the other end of the vinyl tube in a clear container, and fill the container with fluid during air bleeding.
3. Working with two people, one should depress the brake pedal a few times and then depress and hold the pedal down.
4. While the brake pedal is being held down, the other person should loosen the bleeder screw using the SST, and bleed any fluid containing air bubbles. Once completed, tighten the bleeder screw.
5. Repeat Steps 3 and 4 until no air bubbles are seen.
6. Perform air bleeding as described in the above procedures for all brake calipers.
7. After air bleeding, inspect the following:
• Brake operation
• Fluid leakage
• Fluid level
Old Jan 17, 2011 | 05:43 PM
Great post, thank you What fluid would you recommend?
Old Jan 17, 2011 | 06:11 PM
I like ATE SuperBlue...it's blue and easy to tell when you have flushed it through. You can use the Amber colored 2000 alternating the 2......same fluids...different colors basically
It isn't the best fluid..but for the price it's up there....
DocBeech's Avatar
I drive at Red Line.
https://www.rx8club.com/showthread.p...05#post3851505
Old Jan 17, 2011 | 07:39 PM
DocBeech's Avatar
made this one just for you ross:P
https://www.rx8club.com/showthread.p...89#post3851589
theblinkof
Oct 4, 2023 05:24 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
XianUnix
Sep 29, 2015 03:48 PM
