Dome Lighting Mod
Old Feb 15, 2004 | 07:44 PM
Flawless's Avatar
Arrow Dome Lighting Mod
I would like to mod my internal overhead lights ( dome lights ). Basically I would like to change the bulbs to something similar to a xenon... bright white with a bluish type tint to them. Does anyone know what type of bulbs are in those dome lights and where I could get them? Also... does anyone know how to dismantle the overhead console thing which has the lights and glasses holder in it to actually get in there to change the bulb? Any help would be greatly appreciated...
Old Feb 16, 2004 | 11:37 AM
tommy12g's Avatar
Pistons.. What are those?
I did the changes, for the bulbs on the map lights you use w5w bulbs or LED's i used LED's it is very simple to remove just take out the 2 screws hiding in the glasses holder, then just pull it out it is just pressure placed in there, then for the dome light just get a 36mm LED white and that is all you need , you can get all this on ebay, also FYI.. the interior parking lights, the courtesy door lights as well as the map lights all use the same bulb.
Old Feb 16, 2004 | 03:22 PM
ELX13's Avatar
CHAH-LAY MURPHAAAAAY!
i also changed all my interior bulbs flawless...they're all 168/194 size.
FYI...the instructions for changing those (and all) bulbs are in your owner's manual.
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Irvinb16
Sep 11, 2015 10:27 PM
