Oil brands mixing?
Old Feb 12, 2004 | 10:14 PM
Rotary Titus's Avatar
Oil brands mixing?
I'm going to buy a bottle of 5W-20 to keep in my trunk. I was wondering what brand mazda dealers use? Does it matter if I use the same brand that they put in at my service?
Old Feb 13, 2004 | 02:19 AM
Nubo's Avatar
Lubricious
I've read that it's best to stick to a single brand in case the different additive packages don't work well together.
Old Feb 13, 2004 | 06:32 AM
rx8cited's Avatar
Re: Oil brands mixing?
Hi Rotary Titus,
Here's an opinion for you from CITGO
"Myth: You can't mix brands of motor oil.
Fact: Mixing brands is not the best practice because the additive systems in each may be different and when mixed may not function as efficiently as desired. However, no serious problems will occur if you must add a different brand of equivalent quality between oil changes. It is very important to maintain proper oil level. "
I'm personally going to continue using my case of Castrol in between oil changes regardless of what brand oil the dealer uses during my oil changes. It gets too complicated logistically otherwise.
Here's another reference that says basically the same thing.
regards,
rx8cited
Old Feb 13, 2004 | 02:06 PM
I see....
thanks!
Old Feb 13, 2004 | 05:51 PM
r0tor's Avatar
All the oil companies are pretty much using the same kinds of additives anyway nowadays, just in different quantities. Its not going to hurt anything.
Old Feb 22, 2004 | 07:11 AM
Trx8's Avatar
Is Scarce
I checked with my dealer to see what they use when they change the oil (Motorcraft 5W-20 Blend). I now carry that type to top-off the oil. I am at ~1800 miles, am down 1/2 quart, and haven't added any yet.
Old Feb 22, 2004 | 07:32 PM
motorcraft eh?....
any recommendations on the "best" oil without going synthetic?
Old Feb 22, 2004 | 09:30 PM
RX82004's Avatar
I know my dealer uses some form of Castrol 5w20...just put a bottle in...so do not all dealers use the same?
Old Feb 23, 2004 | 05:56 AM
rx8cited's Avatar
motorcraft eh?....
My favorite flavor ice cream .... um motor oil is Castrol GTX 5W-20. :D.
Old Feb 25, 2004 | 11:54 AM
MyLadyDeb's Avatar
so then my question is - because my old car mechanic asked me - are we NOT to use synthetic oil in the RX-8? Stick to the 5W-30? I'm at 2,200 and down about 1/2 quart - haven't added anything yet. Want to do it right from the get go. Thanks.
gwailo
May 14, 2024 06:57 AM
20b-3rotor
Sep 2, 2015 08:54 AM
wayloco
Sep 1, 2015 09:03 PM
Sifu
Aug 30, 2015 10:51 PM
Psychofox
Aug 20, 2015 04:48 AM
