Got a question regarding the midpipe...
Old Feb 12, 2004 | 10:24 PM
Japan8's Avatar
Int'l Man of Mystery
loud. Too loud for street applications according to reports from people who've run it. Even those how traded the cat for a high flow/high temp cat had to add a resonator before the cat-back, simply because it was too loud.
If loud is what you want... then you've got no problem, but if you want something easily streetable (i.e. don't call cops attention to you)... then you may want to consider adding the resonator.
Old Feb 12, 2004 | 11:57 PM
i was planning on doing the same thing...just go to a local muffler shop and make one...and don't forget to add flanges on both sides of the pipe so you can take it off and put it back on when you need too...that mod will probably cost you only $50 bucks at the most... $50 vs. $250 ?? you guys do the math..
Old Feb 13, 2004 | 02:22 AM
Psychofox's Avatar
我愛台妹,台妹愛我
by doin this will i get CEL? if it does what should i do? thanks
Old Feb 13, 2004 | 03:00 PM
djmano's Avatar
RX-8 Pilot
your gonna need some kind of 02 sensor simulator to trick the car into thinking the cats still there. or else you will get a CEL.
Old Feb 13, 2004 | 05:51 PM
rotarygod's Avatar
CEL : Check Engine Light
O2 simulator is a little "simulator" box that plugs in where the second O2 sensor is. This fools the computer into thinking that there is still a properly working O2 sensor hooked up running through a cat. No CEL.
Old Feb 14, 2004 | 03:30 AM
so how do you fool the cel again great roatry god?
Old Feb 14, 2004 | 01:39 PM
rudy8's Avatar
troy,,,call canzoomer.com.
i have talked to him re the same stuff and he will help.
rudy
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
