touch up paint for dummies
Old Feb 12, 2004 | 12:33 PM
mikeb's Avatar
100% Italian
mazda sent me touch up paint as a gift
everytime I use some on my hood or front bumper on chips my car looks worst.
whats the best way to apply touch up paint?????
Old Feb 12, 2004 | 12:52 PM
Astor's Avatar
They Come At Night
I've read with either the end (where it rips from the book, not the tip) of a soft match, or possibly a toothpick, layering the paint a drop at a time, let it dry, then reapply. I haven't actually tried this, it's too cold to get out and have much patience. Then after filling, I believe you use some sort of polish or compound to buff it smooth.
Old Feb 12, 2004 | 01:39 PM
mikeb's Avatar
100% Italian
I have used a toothpick but I never reapply or buff after
maybe thats the problem
Old Feb 12, 2004 | 01:56 PM
cardinal35's Avatar
a guy I know at the body shop says the match trick as well- just let the drop of paint fall by itself into the paint chip or scratch and then it will fill itself- also he says they (for scratches) have a VERY fine brush they basically fill the scratch with-ABOVE ALL he said to use patience-ALSO I just saw on the duplicolor site (the people that make the metalcast paint) they have some new touch-up ball-point pen- not sure about color matching though
Old Feb 12, 2004 | 02:48 PM
Hard 8's Avatar
Senior "Member"
I'm no expert, but here's what I've gleaned from various sources and my own experience: (1) The paint shrinks as it dries, so if you overapply, it will dry a lot smaller than when you started. (2) The product called Langka ("the Blob Remover") works OK to remove the excess after it's dry, but it will completely remove the touch-up paint sometimes, especially if it's not OEM touch-up paint, even if it's been dry for years. (3) Alternatively, if you overfill the hole, you can let it dry, then glue a circle of fine (1600?) sand paper to the end of a pencil eraser, and use it to sand down the excess, then polish it.
Personally, I wash the car, then use a fine paint brush from the hobby store, fill it in a couple of times to account for shrinkage, then either leave it alone or touch it up with Langka. I haven't tried sandpaper. Usually looks pretty good.
Old Feb 12, 2004 | 03:25 PM
mikeb's Avatar
100% Italian
good info guys, thanks
I've seen a commercial for that ball point paint pen and it looks pretty good
Old Feb 12, 2004 | 03:37 PM
rex's Avatar
rex
Revvus Maximus
Interesting thread!
I'm thinking out loud here...
If you overfill the chip, I wonder if using a razor blade at a shallow angle to the surface would allow you to carefully shave off the excess paint? Then you could carefully buff with a mild abrasive. I've had good success using metal polish to remove scratches from plastics, so perhaps the same might apply to clear coated surfaces?
Someone let their dog jump up on my Miata last year and gouged the rear bumper. I've been wondering ever since what the best approach would be to get the filled area flat again.
Old Feb 12, 2004 | 03:48 PM
Genom's Avatar
Not so Super right now
If you overfill just sand it (GENTLY) down using finer and finer grits. I've been doing this and then a quick polish/zaino. Still working on tecnique, but they already look better than the one sI just dabbed the paint into.
Old Feb 12, 2004 | 08:39 PM
jtdwab's Avatar
I haven't used by touch up paint yet but I did some hunting. Everywhere said use the match technique then use 2000 grit sandpaper to sand it. Punch the sandpaper with a hole puncher and glue the "holes" onto a new pencil eraser (new meaning flat and round). Apply one drop at a time and allow to dry a couple of hours then do it again. Lastly cure several weeks before waxing.
I want to do my first Zaino applicaiton but I also want to fill in one scrape and one chip first. It cold right now so I'll bet it will take more than 2 hours for each drop to dry.
Old Feb 12, 2004 | 10:13 PM
mdw33333's Avatar
OK, tooth picks and matches tend to work well. I've found that the best way to apply touch-up to the "smallest" rock chips, scratches, etc., is to find a regular fine bristle paint brush. Take and rip out "a single bristle." That's right, just one bristle. Barely dip it in the touch-up and allow it to just drip onto the rock chipped area. As posted above, the paint just "fills" the area. You may need to wipe away failed attemps, and try this multiple times before getting it right, but the "single bristle technique" has worked well for me.
Old Feb 16, 2004 | 02:59 PM
boothguy's Avatar
The matchstick method is a good one, but in case anyone's interested, Griot's has a package of one-time applicators that do a more precise job. The sandpaper-on-an-eraser idea has also made the rounds and certainly sounds like it'd work. For "over-fills", professional body shops sell small shaped cutters embedded in a plastic block that will "shave" dust nibs and sags from new paint jobs. You can also order them from Eastwood Company online.
Old Feb 16, 2004 | 05:39 PM
beachdog's Avatar
There is a very detailed DIY for repairing chips with touch-up paint at www.autopia.com I am not posting the instructions because they are copyrighted. You can download the detailing book at no charge.
Old Feb 17, 2004 | 06:56 PM
rx8gator's Avatar
Get up and go!
Thanks for the info. I scratched my 8 yesteday with a hanger from the drycleaner, and coincidently, my "gift" showed up today! They must have known. I'll try the methods here to see which one works for me, and post my results. Thanks, forum mates.
Old Feb 17, 2004 | 11:13 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Guys- Before you start sanding anything, check this stuff out:
http://www.langka.com/
I was recently keyed on my hood and fender- mildly and not very deep, but still several feet of scratches that pissed me off to no end. Anyway, I found this stuff after some recommendations on this board. I haven't done the scratches yet, but I have done a test on a small chip to get the hang of it... it's incredible.
It's basically a solvent for touch-up paint, but not OEM automotive paint, so it can smooth out the 'blobs' that touch up paint leave. The great part with this stuff is your supposed to leave a blob, so you don't have to be super careful- then come back when it's dry a few hours later and use this stuff to remove the blob excess. Scratches are a bit different, but can still be done with a little more care, which is why I'm practicing on chips : )
Their site explains it better than I do, but it's definitely the answer for my touch-up needs. You can probably find other threads on here that discuss it as well...
Old Feb 17, 2004 | 11:23 PM
G8rboy's Avatar
Sorry to be redundant with my last post- I didn't see that Langka had been mentioned already.
Old Feb 18, 2004 | 05:11 PM
MadMacz's Avatar
One other idea that works well, especially with deep gouges. Try cleaning out the damaged area with a sanding pencil. It looks like a regular pencil with a fiber optic tip. It really cleans out the rough edges and lets the touch-up paint leave a smoother surface.
Old Feb 19, 2004 | 11:16 AM
emailists's Avatar
BTW Lankga is also sold at many Auto parts stores as McGuires with Lankga, and A few other mainstream wax co's as well, so you may find it locally. I used it, but it ended up taking all the added touch up paint off. I'm sure it will work in som instances, and at the very least allows you to undo mistakes.
Old Feb 19, 2004 | 06:08 PM
maxrx8's Avatar
I got two bottles. One as a gift and the other from the phone survey. I attempted my touch up last weekend. Nightmare first application. I quickly rubbed it off. I found that if you let it do set in the scratch or what ever it will settle, and look good. Just don't try and play with it too much. I have to look very hard to see where I put mine now.
max
Old Feb 22, 2004 | 04:20 PM
rx8gator's Avatar
Get up and go!
Thanks mikeb and all. I'll try the Langka product. The Mazda paint sets up so quickly, that doing it with just their paint is impossible. It gets sticky in only a few seconds. If you can leave a blob, and then work with it, that is best. If it works, I'll post my results,
Old Mar 6, 2004 | 12:21 AM
Blue87Sport's Avatar
Rotary only since 1980
Actually its at www.autopia.org not www.autopia.com. Look under the downloads section.
The .com site is for dentistry so if you have rock chips in your teeth, go there. :D
Old Apr 28, 2004 | 10:55 PM
B-Nez's Avatar
I just got an inch-long scratch down to the primer tonight courtesy of an SUV door-corner. Think the touch-up paint will be okay to use for this? I really want to avoid the whole body-filler and paint-blending thing at a shop. I can post a photo tomorrow...battery in my camera is about dead.
Old Apr 29, 2004 | 12:00 PM
mikeb's Avatar
100% Italian
sorry to hear
I got something similar yesterday and I'm gonna try to wax the crap out of it
Old Mar 19, 2007 | 12:21 AM
NomadEpitro's Avatar
Stick pins from those folded up dress shirts you buy at Kohl's work well as drop applicators also...
Old Mar 19, 2007 | 12:05 PM
savedsol's Avatar
Carbonormous
You can get color matched paint pens, rattle cans and stuff at paintscratch.com Good stuff.
