Anybody else has Tanabe Springs Installed? Tech question
Old Feb 10, 2004 | 10:20 PM
rx8power's Avatar
Boricua Hasta La Muerte
Anybody has tanabe springs installed? I installed mine and put the short ones in the front and the tall one in the rear. But I noticed today that from the factory the short ones are the rear ones and the tall ones in the front. Please let me know if this is correct.
RX8Power
Old Feb 10, 2004 | 10:35 PM
DALE A BREDE's Avatar
The new springs go exactly the same as factory, short rear tall front. You also had the problem with the car looking funny with your new springs didnt you? so this will explain your issue.
Dale
Old Feb 11, 2004 | 09:02 AM
XeRo's Avatar
Normality is Obscene
Yup..sorry buddy..you put them on wrong...Longer springs go up front to make up for the added weight of the engine compartment...I bet you looked pretty hilarious <- that's not an insult, i guess after you get it corrected you can then laugh at yourself.....don't worry though you shouldn't have caused any problems...just a PITA to do over again....
Old Feb 11, 2004 | 10:41 AM
rx8power's Avatar
Yeah, I don't take it personally, that ****'s hillarious, I'm laughing about it right now. I called Tanabe and told them suckers that the part # for the springs are backward. As far as doing it again, the first time was a pain in the ***, but now should be easy since I GOT THE EXPERIENCE. :D
Thanks for your input guys, you really help me a lot. Will keep you posted on how it goes.
RX8Power
Old Feb 11, 2004 | 11:05 AM
Gyro's Avatar
Rotary Abuser
Question
I thought the car had 50/50 weight distribution?
Old Feb 11, 2004 | 02:03 PM
slaughter's Avatar
Which Tanabe's did you install and do you have Pix? I've got the GF210's on order and am praying the front will lower more than the rear.
Old Feb 11, 2004 | 03:10 PM
rx8power's Avatar
slaughter,
I used Tanabe's NF210's, when you get your GF210's make sure you install the long ones in the front and the short ones in the rear, don't do like I did. I'll give you pics when I fix my orientation problem.
Later
RX8Power
Old Feb 11, 2004 | 03:11 PM
slaughter's Avatar
so are you satisfied now that the install is correct or should i return mine the minute UPS drops em off?
Old Feb 11, 2004 | 06:53 PM
rx8power's Avatar
Well, I have not correctly installed the springs yet, off course I'm not driving the car, but I'll be doing that friday. Keep your springs for now and I let you know friday. I'll even send you a picture of how it looks with the new springs. OK
RX8Power
Old Feb 16, 2004 | 10:12 AM
310Guy's Avatar
4AT poor mileage king
I'd like to see how the springs look installed. Thanks.
Old Feb 16, 2004 | 10:24 AM
XeRo's Avatar
Man...i knew someone would notice this...i tried not to get into a longwinded one here cause, Rotarygod is good at that stuff..heheh...sorry buddy,....anyway...i should have been more clear...while you are correct in the 50/50 wgt distribution, that only pertains to the car at standstill...you have to look at the forward momentum weight when travelling at any speed in which you subject the car to G's whilst turning. These take into account nosediving, heavy braking. If you've been to an autoX event or actually any race regarding swift turns, chicanes, or switch backs...watch the front end of the car...your forward momentum, which under and over steer play into this also but i don't wanna get that far into this..., you will see the nose of the car dive as the weight is transferred to the front...
did i make sense here?..if not..i'll try again...to put it in short form...any physics book under forward momentum in the index...they always have a car on a race track when discussing this....
Old Feb 19, 2004 | 11:03 PM
RX8on19s's Avatar
I got my NF210 today and I plan to install them this weekend. Can you post some pictures so I can see what it is going to look like?
Thanks,
Old Feb 20, 2004 | 10:44 AM
Shocka's Avatar
WHAT.... YEAH... OK!
where did u guys order them from? prices? pics?
Old Feb 20, 2004 | 11:03 AM
slaughter's Avatar
GF210's from Hop Up Racing, $169 I think was the price.
Will post Pix when I get new (working) camera.
Old Feb 21, 2004 | 04:32 PM
RX8on19s's Avatar
Did you have any issues putting on the front spring?? The bottom part is not landing right?
Old Feb 21, 2004 | 05:03 PM
neit_jnf's Avatar
Maybe they just designed the front and rear suspension diferently and have different mounting points thus different lenght shocks/springs?
Old Feb 21, 2004 | 06:07 PM
zmzmrx8's Avatar
I have the purple Tanabes (NF210) on my car and I believe I put the long ones on the front and short ones on the rear. 1 inch drop all 4 corners.
Old Feb 21, 2004 | 09:23 PM
Genom's Avatar
Not so Super right now
Not really. You just need larger springs in front since there's a lot more stress on the front end (weight transfer is aimportant thing to elarn about). Thats also why your front brakes are larger too. If the car drove in reverse all the time, then it would be the other way around.
Old Feb 21, 2004 | 11:46 PM
RX8on19s's Avatar
Exclamation
Guys,
Here's the real deal...
Stock setup:
Large in the front
Small in the rear
I installed the Tanabe NF's today (Sort -Sort & Large-Large) and it did not work. The front was on the floor and rear was up in the air.
Tomorrow, I will be changing them around. Tanabe is using Small ones in the front and large ones in the rear. The size does not matter in this case because they are compensating the difference with a stronger spring rate.
I will let you know how it turns out tomorrow.
Old Feb 22, 2004 | 12:08 PM
rx8power's Avatar
You're right, I had the same issue and Tanabe messed up, the springs will not fit in the car, I talked to the guy @ tanabe and he was supposed to call me back, but he never did. Once again "They will not fit", the parts numbers show the long ones for the back and the short ones in the front, but is supposed to go the other way around and if you switch them, they will not fit on the strut perch. So what I did was, I just put the short ones in the front with the stocks in the rear and the car looks just the way I wanted. Kinda like stock but not with the big gap in the front.
RX8Power
Old Feb 23, 2004 | 05:00 PM
310Guy's Avatar
RX8Power,
Any pix with your set-up? Thanks.
Old Feb 23, 2004 | 07:28 PM
XeRo's Avatar
anyone wonder if Tanabe did a little R&D before cranking out some springs for the 8?
Old Feb 23, 2004 | 10:50 PM
rx8power's Avatar
310Guy
I'm gonna borrow my friend's digital camera so I can post pics by wed.
RX8Power
Old Feb 24, 2004 | 04:19 PM
RX8on19s's Avatar
I installed my and they look fine now.....The back has no gap and the front has about two finger gap. It rides nice....
Old Feb 24, 2004 | 04:26 PM
Gyro's Avatar
Rotary Abuser
Picture?
