shifting
Old Oct 4, 2010 | 10:42 PM
Arun9's Avatar
shifting
im new to manual and i got the hang of it in a couple of days and i just had a couple of quick questions
1. how did shift faster to first gear?
2. can someone tell me like the range of speed u should be on for each gear
3. any tips for driving stick
Old Oct 4, 2010 | 10:43 PM
dozer's Avatar
on his 3rd rx8
149 in 5th gear
Old Oct 4, 2010 | 10:48 PM
WTBRotary!'s Avatar
Drummond Built
Old Oct 4, 2010 | 10:52 PM
HockeyRX-8's Avatar
TNC
someone needds to introduce him to the "secret" shifting method
Old Oct 4, 2010 | 10:53 PM
WTBRotary!'s Avatar
Drummond Built
I like shifting into 1st around 40mph... just slam it in and you will be good... just let the synchros do the work...
Old Oct 4, 2010 | 11:02 PM
Tweek's Avatar
RobotsToRobots.com
am i the only one that doesnt shift at all?
Old Oct 4, 2010 | 11:04 PM
HockeyRX-8's Avatar
TNC
Found the thread about shifting
https://www.rx8club.com/showthread.p...ecret+shifting
Old Oct 5, 2010 | 04:24 PM
Arun9's Avatar
thanks hockey
Old Oct 7, 2010 | 03:20 PM
bkcberry's Avatar
It's like the OP went to walmart and asked to speak to a doctor
Old Jan 14, 2011 | 01:46 PM
vicneu's Avatar
vicneu
shifting
Sometimes when the engine and trans are cold, its easier to shift into 2nd then into first.
For economy purposes, I often shift 1,3,5, then 6.
Don't get over the redline too often in any gear...I shift around 4-5,000 rpm to save some gas.
Learn how to double clutch, it helps save wear and tear on the clutch.
You can also learn to blip the throtle between gears when downshifting, it keeps the revs from dipping too low when the clutch is in, and makes the shifting much smoother.
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
