Problems with Cobb?
Old Sep 29, 2010 | 08:59 PM
jDt!'s Avatar
Problems with Cobb?
I just recently put a greddy turbo kit in my car and I am going to be using cobb access port with tuning by MM. I put the base map in for FI and I drove it around for a bit and besides it running very rich, which I am assuming the map is meant to do, when I get the car really warm after driving it for about 10 mins I start getting smoke out of my tailpipes. It's not oil because I had that happen before on a previous engine and the oil level is staying constant. It almost seems like it is so rich that I am burning so much fuel that the fuel may be causing the smoke? Also the temp gauge reads normal for the car, but when I run the car in neutral and keep it at 4k for about 5-10 seconds the overheating light will come on, but as soon as I let off the gas it went away. The coolant level is normal also. Any Ideas what this could be?
Vedivan1
Sep 20, 2015 04:39 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
BigBadChris
Sep 7, 2015 01:49 PM
