Racing Beat front sway bar install problems
Old Sep 6, 2010 | 10:19 AM
pyroshock's Avatar
So during the install of my front sway bar i was removing the old bar and a bolt broke. I was using a 3/8 inch hand ratchet and the part got a few turns on it and then the bolt sheared off with the nut. (I don't think I'm that strong so maybe the bold was damaged)
See attached pictures.
So after talking to my mechanic friend he said it looks like the bolts are pressed it and should be able to be removed and replaced. However when I went the the suspension parts catalog for a part number it wasn't listed.
So here's what I want to know. Is it replaceable without remove the whole assembly? If so how? If it is not replaceable can the bolt be drilled out and then replaced with another bolt.
Attached Thumbnails Racing Beat front sway bar install problems-dsc00552.jpg   Racing Beat front sway bar install problems-dsc00553.jpg   Racing Beat front sway bar install problems-dsc00555.jpg
Old Sep 6, 2010 | 10:28 AM
expo1's Avatar
He's as bad as Can
At this point drilling it out will not make anything worse. I would try that and get a high quality nut/bolt lock washer.
Old Sep 6, 2010 | 12:59 PM
fastlaneracing's Avatar
Rotor User
I did the same thing last time I greased my swaybar bushings, I drilled it out and replaced it with a loose bolt. it was easy to drill out...
There will be no differance afterwards.
Pelleilee
Sep 29, 2019 10:07 AM
8is>enuff
Sep 24, 2015 08:57 AM
RXeckless
Aug 16, 2015 12:52 PM
MolecularConcept
Jul 26, 2015 09:09 PM
AussieGray
Jul 16, 2015 03:58 AM
