Aero development?
Old Sep 3, 2010 | 11:52 AM
BlueRenesis82's Avatar
Registered Tracker
Aero development?
Has anyone done anything as far as aero development with the car? Other than the Mazda com stuff.
Old Sep 24, 2010 | 11:26 PM
8upbad's Avatar
Jared
Good question. If I had money I would totally be making parts to try and maximize down force (not necessarily heavy df, more like df in the right places) and air flow.
Old Sep 25, 2010 | 01:18 AM
yiksing's Avatar
the giant tastetickles
If I had the resources, I would seal the whole bottom of the car. Get ducting for the side vents to a sealed engine bay, front ducting to the radiator and custom a vented front hood with a duct to extract radiator heat by sealing it behind the radiator fan. Get rid of the table top rear trunk and custom a real coupe rear windshield that ends with a slight angled duck tail. Lose the dual exhaust and get a straight pipe for the exhaust piping ending with a slightly angled upward single tip exhaust in the middle of the rear bumper.
Old Sep 25, 2010 | 10:14 AM
olddragger's Avatar
you can start by ordering the 09+ underpanels--they actually do help--quite a bit.
To add to the above good ideas--i would go with a smaller outside mirrors
better front lip (sort of like the autobaun front bumper with addtional spitter/ lip, clean the underside of the rear up a lot with a small diffuser. shave the doorhandles, hide the windshield wipers, tires and wheelwells closer, open up the side vents,
and paint it red.
OD
get rid of the rotor symbol on the hood
wheels closer to the
Old Sep 25, 2010 | 10:40 AM
Gee... you guys are getting ridiculous.
The 8 doesn't have the power to overcome any more DF
Old Sep 25, 2010 | 11:11 AM
^^ nevermind that you have no experience with it.
It really depends on the time in the corners vs straights, the speeds involved, and the specific designs involved.
Old Sep 25, 2010 | 11:13 AM
Easy_E1's Avatar
Someone plays Forza.
Old Sep 25, 2010 | 11:27 AM
Never have
I have an APR 3" splitter and GTC-200 wing. For autox (sub 60 mph) it doesn't make much if any difference. For mid-speed time trial events it comes in nicely allowing higher (75 - 90 mph) sweeper and transitional speeds with little impact on the straights.
Not having a weak engine helps ...
Old Sep 25, 2010 | 11:32 AM
Easy_E1's Avatar
JK I just remember seeing that under the Aero tuning section on Forza. Basic stuff.
Old Sep 25, 2010 | 11:40 AM
Always been surprised at the design theory in some of those games.....Somebody with an automotive brain actually does a lot of that stuff
I'm far from a gamer but I'm waiting for Nov
Old Sep 25, 2010 | 11:57 AM
Highway8's Avatar
Registered RX8 Nut
Check out the link in my signature. My main focus is a front splitter for the mazdaspeed bumper for downforce on the track used in conjunction with my apr gtc-200 wing. Because of the intrest a splitter for the stock bumper will also be made. A underbelly pan will be made to reduce drag/lift and I will be doing something in the back to smooth out the air flow to my rear mazdaspeed rear diffuser.
Old Sep 25, 2010 | 12:08 PM
ZumnRx8's Avatar
RX8 & RX7 owner
You and I Both.
Old Sep 25, 2010 | 01:18 PM
Registered Tracker
I have been following your thread, I was just looking for any other available tested solutions.
Old Sep 25, 2010 | 03:44 PM
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/gi-functinal-aero-parts-front-splitter-underbelly-pan-200996/
Old Sep 25, 2010 | 08:18 PM
Registered Tracker
Yeah...
Old Sep 25, 2010 | 08:56 PM
It was the easy link for anyone else, I wasn't just focusing on you.
Old Sep 26, 2010 | 08:49 AM
Registered Tracker
Got it, just wanted to make surey reading skills were still working.
Old Sep 27, 2010 | 06:25 AM
EricMeyer's Avatar
Measure, measure, measure. Wind tunnels exist for a reason sports fans. Also, what is the purpose of creating more downforce for you? Additional drag when you drive to the liquor store? Fast and Furious best in show award?
It's funny, the more I learn about how the big boys do it the more I understand how the only answer is to measure things. Often a common theory can HURT a project. What works for one car can hurt another.
Old Sep 27, 2010 | 09:42 PM
olddragger's Avatar
agreed--dont need as much downforce as we need more slip.
OD
Old Sep 28, 2010 | 12:41 PM
Check out this F&F numnut making a shochu run ...
Old Sep 28, 2010 | 12:43 PM
I liked his old car better
XOWii wowie
Old Sep 29, 2010 | 08:06 AM
EricMeyer's Avatar
Dang. Tough crowd. The new 32 car (pictured) is faster than our other two flat black cars. With much better planning and more $ we were able to shave close to 200 lbs. Dry weight 2,601 w 1 gallon, cool suit. No fat zzz driver
Old Sep 29, 2010 | 02:13 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
At the AAA Speedway roval we talked KJ into taking off his poser STX wing, he went 7mph faster on the straits, and posted a quicker lap. Sure he wined about the car being loose, but loose is fast.
Old Sep 29, 2010 | 08:28 PM
But again, you have to consider that the old-style dual element aluminum wing isn't anywhere near as efficient as the current shaped single element wings. Not saying that the same wouldn't have occurred with one, but rather that we'd need to test both back to back to compare the degree of how relative the general differences are.
Old Sep 30, 2010 | 12:33 AM
kjchristopher's Avatar
Heck, I'm thinking about leaving it off for solo next year....
Hiroshima_RX
Sep 21, 2015 06:28 PM
mitchrx8
Sep 13, 2015 08:05 AM
