NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
2004 Rx8 Stalls in the Highway
Old Aug 31, 2010 | 07:43 PM
Azam1030's Avatar
NY 2004 Rx8 Stalls in the Highway
I have posted this before:
Hey all, so I have a 2004 rx8 with about 78k miles. While driving on the highway for about 20 mins, when I have to brake and slow down, the RPM needle goes down to the idle state than the car would automatically shut off. I would have to wait a minute or two before starting the car again and it takes sometime before the car could idle properly (The car struggles to stay on)
Since than, I have checked the Coils, fuel pump and change the CAT. The car is still having the same issues. I was told to check the MAF and compression of the car.
I was planning to buy a MAF online to replace my older one because I saw another thread which had the same issues as my car. Once they changed the MAF, it fixed the problem entirely. Any other suggestion will be grealty helpful.
Old Aug 31, 2010 | 10:42 PM
I think its better to check your MAF before you throw that 100 something bux out, and you might end up with nothing.
Old Sep 1, 2010 | 10:33 AM
Gambit's Avatar
Screw gas mileage
Given what you've already done, i say clean the MAF first with a spray cleaner available at any auto parts store, or like walmart.
if not, get the compression check, you might need a new engine
Old Sep 1, 2010 | 11:48 AM
Azam1030's Avatar
NY
Thanks guys, I will take a look at the MAF, hopefully that will fix the issue
Old Sep 1, 2010 | 03:43 PM
HockeyRX-8's Avatar
TNC
A member here named Klepto also had the same problem...though IDK if he ever found what was causing it....try sending him a PM
Old Sep 2, 2010 | 12:39 AM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
I HAVE THE SAME ISSUE...cleaned the maf sensor and throttle body...its a little better but still vibrates a little and shuts off only when i go in reverse after long time of driving it and when i have the ac on...weird!! iknow...im missing the rear o2 sensor...just ordered it, hopefully it will fix the problem...
Panthersn
Jul 13, 2021 06:30 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Mr.Durden
Aug 12, 2015 02:21 PM
RX7.9
Jul 20, 2015 12:01 PM
