Engine Problems
Old Aug 30, 2010 | 10:51 AM
Mazda_RX804's Avatar
Hate Scrape 8
Engine Problems
ok so yesterday, I went to go start my car and it was idleing very low, when i revved, it sounds low and deep (Like a subaru STI) and everything was shacking the exhaust, shifter, motor. I had the ENGINE LIGHT FLASHING. turned it off, let it cool off. disconnected battery, then tried 30 mins later. Same thing. I called rick, he said it would be ok to drive with the flashing light. so i did.
I drove 5 kms, then smoke started coming out of the engine, and my exhaust was burning hot to the point it was burning blue. I had to call for a flat bed, and got it home. When I got home i turned it on to put in the garage, the the engine light was now solid (no longer flashing)
When I got home i used my scan guage to check the coded. I had 2:
P0171- O2 sensor
P0301- Misfiring Issue
I have an appointed at mazda on thursday at 8am.
Anyone know if this is a serious issue? What am I looking at here? I can sleep, I so stressed with this issue, I do my oil changes and dont cheap out on gas, I do everything dealership asks me to change, I recently did the spark pluges, and even have a new cat. Did my cat back create this problem? Any help or tips will be greatly appreciated guys. Thanks
Old Aug 30, 2010 | 12:57 PM
superleggera123's Avatar
soo sorry bro
dont worry
it will all be ok
Old Aug 30, 2010 | 01:05 PM
Ka Kui's Avatar
Oh man, this is not cool at all......
Old Aug 30, 2010 | 01:52 PM
Hate Scrape 8
is my engine fucked?
Old Aug 30, 2010 | 04:21 PM
Ka Kui's Avatar
What I mean is, you followed what the dealer asks you to do, but the engine is not behaving well.... let's hope it's nothing serious.......
Old Aug 30, 2010 | 07:18 PM
REV-illusions's Avatar
rotary ninja
heh... check the plug wires... could be as simple as one of them is disconnected... or just not firmly on... otherwise.. coils or engine is bpth... likely
Old Aug 31, 2010 | 01:51 AM
Hate Scrape 8
engine is bpth??
Old Aug 31, 2010 | 01:52 AM
Hate Scrape 8
also forgot to mention, the exhaust had a white powdery susbstance inside the exhaust, would that be baffle from the cat?
Old Aug 31, 2010 | 09:46 AM
Footman's Avatar
Dodging those Corollas
The last time I saw a very clean inside of the exhaust with white powdered walls was after a track session...
Old Aug 31, 2010 | 12:29 PM
Hate Scrape 8
never been to the track
Old Aug 31, 2010 | 12:49 PM
DarkBrew's Avatar
Extraordinary Engineering
DTC P0171 - System too lean
http://www.blackhaloracing.com/shopm...200100W20.html
DTC P0301 - rotor misfire detected fire
http://foxed.ca/rx7manual/2003mazdar...200300W02.html
Don't panic. Don't guess. Work your way through the diagnostic guides
Pull the plugs, take a picture and post. We can tell a lot from plug condition
Old Aug 31, 2010 | 02:28 PM
TopGunRX8's Avatar
Would agree with that. That said, neighbour (Railton...he was on here I think) had the Misfire error before his engine was replaced.
It's an '04...from what I've read, it's a matter of time. Thankfully we've got an 8 year warranty.
Old Aug 31, 2010 | 03:10 PM
Easy_E1's Avatar
Ignition coil gone bad.
Fouled sparkplugs.
Cat clogged due to misfiring coil/sparkplugs.
Exhaust overheating due to clogged cat.
White exhaust pipe due to excessive exhaust temps.
Old Sep 1, 2010 | 01:52 AM
Hate Scrape 8
so when this issue is resolved, does my engines life seem to be coming to its end???
Old Sep 1, 2010 | 05:01 AM
RXeckless's Avatar
Rotorless
Mike, don't panic, Dark and others have lead you in the right direction. Your going to your dealer tomorrow anyway but in the mean time, how many km's are on your wires and coils. Your cat was replaced just recently did you check your O2 sensor leads. Don't assume the worst it could be as simple as a fouled plug!
P.S. Also did you check for a exhaust leak like I said on the phone, must likely around the new cat installation.
Old Sep 1, 2010 | 09:03 AM
Hate Scrape 8
I cant seem to see anything for exhaust leak, Ive had the spark plugs done 4 months ago. maybe 8000kms ago?
Old Sep 1, 2010 | 04:45 PM
Railton's Avatar
Spend a $100 at the dealer when you take it in and have the compression checked. Make sure they write the numbers down on your service record then compare it to the chart.
Railton
Old Sep 1, 2010 | 06:15 PM
RXeckless's Avatar
Rotorless
Plugs could still be fouled. pull and post a pic as dark said or just wait for the dealer tomorrow.
What kind of mileage on the coils & ignition wires, and did you check your ignition wires are seated good.
Old Sep 1, 2010 | 09:00 PM
TopGunRX8's Avatar
Railton
Hey man! Have you come back to a "real" car-person forum?
Old Sep 2, 2010 | 11:11 AM
Ka Kui's Avatar
Any updates? What did the Dealer say?
Old Sep 2, 2010 | 11:35 AM
Hate Scrape 8
they are ****** idiots, im still waiting! i had an 8am appointment and they thought i was just a drop in cause i towed in my car. I went in there fuming and they said they dont know why and **** im so ****** mad right now, and ill prolly have to leave it there overnight if they dont have parts. I officially hate mazda dealerships
Old Sep 2, 2010 | 11:58 AM
Ka Kui's Avatar
Yo, this is retarded man............. ****!
Old Sep 2, 2010 | 12:59 PM
Hate Scrape 8
so they just called asking me to change my front coils and see if that resolves the issue... hope it is...
Old Sep 2, 2010 | 04:33 PM
Railton's Avatar
Hope it is too man but basically they are just practicing mechanics on your car.
What dealer is this BTW?
I think it's time you took it elsewhere. The only thing is...where?
Coils can be changed by yourself as well. Why don;t you purchase some and install them yourself and see if that does it?
Railton
Old Sep 2, 2010 | 04:36 PM
Railton's Avatar
Not full time TG, just nosing around...besdies, people don't talk about interior plastics and tactile feel all day long here.
Railton
