AT base brake upgrade
Old Aug 30, 2010 | 12:02 AM
ronx8's Avatar
zoom zoom!
Has anyone upgraded from the base brakes on the AT?
Ive been searching around and i know that the base AT does not have the MC brace, or 12" brakes on the front. The rears on both the MT and AT are the same.
So my question is can I just buy larger rotors for the front and it will fit OK?
Old Aug 30, 2010 | 01:06 AM
SayNoToPistons's Avatar
Wheels, not rims!!
No it will not.
Old Aug 30, 2010 | 10:43 AM
Race Roots's Avatar
Former Sponsor
^what he said, the changes would be to extensive. Wheels, calipers, brackets and so forth.
I do have Racing Brake Rotors for the AT's in stock if you wanted to upgrade them.
Old Aug 30, 2010 | 11:05 AM
ronx8's Avatar
zoom zoom!
Yeah Im running 18's at the moment.
As for brakes my pads are running a bit low and I think the rotors need replacing as well.
Old Aug 30, 2010 | 11:12 AM
Race Roots's Avatar
Former Sponsor
You would still need to change out the calipers, the larger rotors is too large for the caliper currently on the AT.
AT Stock Size: 303x24mm
MT Stock Size: 322x24mm (Sport)
Old Aug 30, 2010 | 11:43 AM
ronx8's Avatar
zoom zoom!
I checked out the brake upgrade but I don't think I'm interested in a big brake upgrade. The OEM ones are fine, but I wouldn't mind having the sport suspension brakes.
Anyone know where I can get these?
Old Aug 31, 2010 | 07:55 AM
Kennetht638's Avatar
I looked into this a bunch when I was considering actually downgrading to the AT brakes for rally wheel/tire fitment. It's actually even more extensive than has been mentioned. I believe the hydraulics are a bit different because of the different diameters, so you also need a different master cylinder and proportioning valve.
Old Aug 31, 2010 | 09:33 AM
Wheels, not rims!!
Did you read what RaceRoot posted? Do you understand that you will be swapping out many components? Why do you feel your brakes are inadequate and need an upgrade? Do you track your car?
If you are upgrading just for the sake of knowing you have larger than base model AT brakes, then dont even bother.
Old Aug 31, 2010 | 10:16 AM
Race Roots's Avatar
Former Sponsor
Originally Posted by Kennetht638
..., so you also need a different master cylinder and proportioning valve.
This as well I forgot to mention in my previous post but have researched it on other forums. It can be done but purpose has to be there.
Old Aug 31, 2010 | 11:59 AM
ronx8's Avatar
zoom zoom!
Thanks for all the info.
I thought it would just be a simple caliper and rotor upgrade. (Master cylinder and goodies optional)
My brakes are just fine. I would like to eventually track my car when I complete my suspension so upgrading my brakes would be a plus.
Brokegang
Jan 3, 2016 12:45 PM
Road Cone
Nov 6, 2015 01:52 PM
Chapsy
Sep 22, 2015 09:57 AM
TheRedRotor
Sep 22, 2015 05:30 AM
