Tire Size Question. ASAP
Old Aug 20, 2010 | 12:56 AM
atruerx8racer's Avatar
AJ- THE True Rotarian.
Hello Rotarians,
Looking into getting some new tires, for my 8. Need suggestions on what size I should put for both front and back. I have 18 inch Tenzos, and about .5 inches lowered and I want that aggressive look. What is the max on height, width etc... I can go with. Thanks!
Old Aug 20, 2010 | 12:57 AM
dozer's Avatar
on his 3rd rx8
whats the width of your rims?
Old Aug 20, 2010 | 01:01 AM
Idk...
Old Aug 20, 2010 | 01:05 AM
Idk... I traded my stocks with a buddy's Rx7, who used to own the tenzos I have now. He used to have em on his Rx7 and he has an FC.
Old Aug 20, 2010 | 01:11 AM
Easy_E1's Avatar
Rim width and offset. Those are the key numbers needed.
Old Aug 20, 2010 | 01:18 AM
dozer's Avatar
on his 3rd rx8
^yup...we dont know if your running 7.5s or 9's or even stock width, plus ur offset also plays a roll in figuring out your question
Old Aug 20, 2010 | 02:39 AM
They are stock tires... fitting in the tenzos.
Old Aug 20, 2010 | 10:06 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
Originally Posted by atruerx8racer
Idk...
FAIL
Old Aug 20, 2010 | 10:19 AM
Renesis07's Avatar
Vtak just kicked in yo!!
225/45/R18. Stock tire size.
Old Aug 20, 2010 | 11:44 AM
adamwzl's Avatar
<3's Bunnies
dude I thought you were a true rx8 racer! you should know these things!
Yes we need to know the width and offset of your wheel in order to help you pick a aggressive tire size.
Your friend should know what they are so contact him.
Old Aug 20, 2010 | 11:45 AM
Dude I know what the stock sizes are. I want to upgrade to a much wider and more depth tires. Whats the max on width and height I can upgrade too.. that is my question... which is why i created this thread. As someone mentioned above "Rim width and offset. Those are the key numbers needed." I will find out and get back at you guys.
Old Aug 20, 2010 | 11:46 AM
VashGS's Avatar
Zoom Zoom Addict
Prob would get better results in the Series 1 Wheels and Tires subforum.
Old Aug 20, 2010 | 11:57 AM
245x18 is good
Old Aug 20, 2010 | 12:00 PM
jasonrxeight's Avatar
Idk...
bring out the ruler and measure!
Old Aug 20, 2010 | 12:04 PM
Vlaze's Avatar
The Angry Wheelchair
@ this thread
Old Aug 20, 2010 | 12:05 PM
deadphoenix52's Avatar
meh.
i run 155/80/13 on my rx7. so youll probly want something close to that
Old Aug 20, 2010 | 12:46 PM
fuztupnz's Avatar
Phone Booth'd
atruerx8ricer: you don't want to go any taller or shorter or your speedo will be off. Too much and it could effect traction control. But, without wheel specs, it's a shot in the dark on what to size to tell you. a 245/40/18 will look meaty on an 8" wheel and a little stretched on a 9" wheel. there should be a sticker or stamp on the back side of the wheels or on the barrels that show the specs of the wheel.
Tires won't really be what makes the car look aggressive though, Ride hight and wheel offset are the two main components to this. With the body kit, it would look more aggressive if it were lower.
Old Aug 20, 2010 | 01:04 PM
Never L8's Avatar
In case you didn't notice, you need to provide the width and information others are asking. Just as a point of reference, I'm running 245 40 18 on my 7.5 wheel. This is what it looks like.
Old Aug 20, 2010 | 01:09 PM
Tamas's Avatar
Registered Lunatic
Originally Posted by fuztupnz
atruerx8ricer:
That's either a Freudian slip or a subtle expression of opinion
Old Aug 20, 2010 | 01:21 PM
Supernaut6's Avatar
Dude your interior looks like an aquarium.
Old Aug 20, 2010 | 01:33 PM
fuztupnz's Avatar
Phone Booth'd
Old Aug 20, 2010 | 07:51 PM
DocBeech's Avatar
I drive at Red Line.
+1 ^^
Take a tape measure. Measure your wheel height and width. Then take into consideration where you live. Do you get a lot of rain or snow? Wider tires make for better hydroplaining lol. Also consider do you want to give up handling. If you go with the largest you can fit on the rear, you wont be able to use that tire size on the front due to rubbing and interfernace. IF you have a different size tire on the rear of the vehicle than the front your handling and performance will degrade, I know this from personal experience in other vehicles. You will also decalibrate the speedo. The traction control module either wont work right or will burn out.
just go with 245/40 18 michelin sport a/s plus if you have a 18 by 8 inch wheel.
Old Aug 21, 2010 | 05:42 AM
Never L8's Avatar
^I agree with his tire size recommendation. That would be perfect.
Old Aug 21, 2010 | 07:51 AM
Spin9k's Avatar
Momentum Keeps Me Going
Old Aug 21, 2010 | 08:48 AM
rx8speeddmon's Avatar
Figure out your sizes, then try looking through this thread. https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/will-fit-thread-133500/ Almost all sizes and set ups have been discussed in there and you can always add more to it without getting flamed too bad.
