235/40 on the stock rims
Old Aug 17, 2010 | 03:27 PM
Beefy98's Avatar
Anyone try this? I'd like to put a bit more rubber on the ground with a tad shorter sidewall. I know 245 is correct but I don't wanna go that big. Speedo will read a tad high but I'm most concerned with the steering response. The 235 size really opens the door as far as available hipo rubber!
Old Aug 17, 2010 | 03:29 PM
Meh, why that size. 245/40-18 is better fit.
Old Aug 17, 2010 | 03:30 PM
The Reverend's Avatar
That's a lie
yeh used to run 235/40 federal 595's
Old Aug 17, 2010 | 05:06 PM
Spin9k's Avatar
Momentum Keeps Me Going
I had 235s, works great, perhaps lil better acceleration due to smaller size. I tracked / street drove RX-615s like this for a couple years.
Old Aug 17, 2010 | 05:11 PM
shadycrew31's Avatar
WENTGERMAN
I run 235's all around.
Old Aug 17, 2010 | 07:48 PM
Beefy98's Avatar
Cool. I'm choosing between 190 dollar Star Specs, 264 buck PS2s, and 233 clam AD08s. They are 26, 22, and 25 lbs, respectively. The stock Dunlop 2050s are 25.
Old Aug 17, 2010 | 11:09 PM
R-X's Avatar
R-X
i am running 235 all around on a 18x8.5 buddy club rims works great .on 18x8 should be good. i would highly recommend "Nitto Nt-05". 200 tread wear,AA traction,A Temp. 3 ply sidewall. i used to run 245 and 255 but if your car dose not have extra power .i would go with 235 for over all performance .
Old Aug 20, 2010 | 03:11 PM
pcs's Avatar
pcs
had 245/40/18 nitto nt-05's, got them for $167 per... might be a good option...
Old Aug 20, 2010 | 08:54 PM
Beefy98's Avatar
I see that the 235/40 would put me another half-inch lower! Thats 2 inches along with my lowering. Could I even get up the Rhinos then?
Old Aug 20, 2010 | 09:48 PM
jasonrxeight's Avatar
wonder if running 245/35R19's wound hurt the driftability of my car.
Old Sep 5, 2010 | 10:43 PM
SpencerM1's Avatar
Recreational User
I was wondering the same. The cost difference is huge from going from the 225 to a 245/40/19
Old Sep 6, 2010 | 12:55 AM
but 245/40R19 has a slightly smaller diameter tho, so should be pretty easy to brake traction.
Old Sep 6, 2010 | 01:48 AM
Beefy98's Avatar
a 245/35 is the correct plus zero. a 245/40 is larger in diameter.
Old Sep 6, 2010 | 02:02 AM
That's a lie
im confused yall were talking about stock rims then suddenly changed to 19's
Old Sep 6, 2010 | 04:53 PM
sorry I meant 245/35R19
I was talking about R3's 19's
Old Sep 6, 2010 | 05:25 PM
no-piston's Avatar
do you have picture of 245/35r19 whit drop kit.......i have R3 whit eibach spring and my tire is finish and i look for good tire.....thank in advance...
Old Sep 10, 2010 | 12:22 AM
Rob Cook's Avatar
yea i think that can help us to understand more about this.
Old Sep 11, 2010 | 06:50 PM
Rootski's Avatar
DGAF
I ran 245/40/R17 (yeah, 17) Falken Azenis RT-615's. Fantastic setuo, I recommend it. Don't waste money on all-seasons.
Hunterkelley24
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
