Rust on axles and suspension
Old Jul 29, 2010 | 12:12 PM
04blue beauty's Avatar
Question Rust on axles and suspension
The 04 blue beauty has a severe case of 'cancer' -- rust, that appears to have eaten into the axles on all 4 corners, replacement is a definite. Is this a common occurence or just because it lives in the NE USA? The frame and body are perfect, so it's not everywhere. Best place to get replacement parts or is Dealer the best choice ? Help? and thanks!
Old Jul 29, 2010 | 12:16 PM
RIWWP's Avatar
Before buying any OEM part from the dealer, be sure to ask Mazmart, a forum vendor here. He can get anything OEM, and usually far cheaper than you will pay at a dealer.
And yeah, rust is a northern state issue. Also check the oil lines to the oil coolers, since those rusting through (to the point oil just spurts out and drains) is a problem in Canada that they issued a recall on. Can be a problem here in the US too, but rare enough for them not to issue a recall on it.
Old Jul 29, 2010 | 12:20 PM
Huey52's Avatar
Registered Zoom Zoomer
Unfortuantely just a fact of life due to the salt used on the roads in the Northeast in the Winter (the reason I drive a Jeep 'beater' in Winter instead of my '8).
You have to be really fastideous about undercarriage washing in the Winter, but of course that's often difficult. There is a salt-neutralizing product you can spray on periodically, but fairly expensive and you still have to get under the vehicle to do it properly.
MazMart and other vendors here often have pre-owned parts from warm/dry climates as well as new alternatives that can be more reasonably priced than dealer. Since you cite just suspension perhaps the silver lining is an opportunity to upgrade to higher performance parts (although OEM are quite good).
Edit: RIWWP beats me again, but at least we're on the same sheet.
Old Jul 29, 2010 | 12:26 PM
Wink
Such quick replies! Thank you for your help, will check out mazmart, and will let you know how this works out.
Old Jul 29, 2010 | 12:35 PM
terch1's Avatar
I live in the Northeast and have no rust on the undercarriage of my 8. I have a beater (98 grand cherokee) that I use in the winter. Look into getting yourself a beater. My fiancee has a Solstice and also has a beater (01 Explorer Sport)
Old Jul 30, 2010 | 11:45 AM
VashGS's Avatar
Zoom Zoom Addict
Sounds like encounter with road salt or some other corrosive. Get salvage parts and paint them with hammerite. POR 15 is a horrible product btw it chips off. I just finished a 1st gen RX7 project that was covered with rust. Hammerite Rust cap is best, crushed glass particles and thich plastic like resin. Sand rust, wash off & dry then apply Hammerite. And Lot of WD-40 on rest of car anywhere you see rust. At night use LED flashlight to find rust and coat with WD-40 or do hammerite treatment.
Old Jul 30, 2010 | 12:46 PM
It is doubtful it is structural...so you have options if the rust bothers you...
Old Jul 30, 2010 | 02:47 PM
SleepeR1st's Avatar
It's just surface rust. I live in New Hampshiiiiire, never drove the 8 through snow, and there is still a small amount of surface rust on some of the suspension/drivetrain parts.
Old Jul 31, 2010 | 11:59 AM
VashGS's Avatar
Zoom Zoom Addict
Rust Never sleeps.. if your gonna sell or trade then maybe don't worry about it. If your keeping the vehicle, I plan on keeping my 04, then you deal with it.
WD-40 is your friend. The Hammerite is good stuff too it's sweet
BERG
Oct 8, 2015 09:28 PM
duworm
Oct 1, 2015 04:57 PM
DG07
Sep 28, 2015 10:58 AM
mitchrx8
Sep 13, 2015 08:05 AM
