poor gas mileage / spark plugs?
Old Jul 14, 2010 | 09:20 PM
oric4000's Avatar
I am getting about 170 miles for a full tank. I went to Mazda center today and they said that I probably need new spark plugs and they charge $260!!!
I found a thread of how to change spark plugs on this forum.
I was wondering where online I can buy good/reliable spark plugs for a reasonable price and what kind of spark plugs do I need?
Thanks!!!
Old Jul 14, 2010 | 09:31 PM
maskedferret's Avatar
Oooh, shiny!
http://blackhaloracing.com/products-...-heat-ranges4/
Close to the best price you'll get anywhere else. Don't think you can skimp out with other brands.
Old Jul 14, 2010 | 09:36 PM
oric4000's Avatar
$80 for each spark plug? that makes $320 which is more expensive than in mazda service center...
Old Jul 14, 2010 | 09:37 PM
Oooh, shiny!
That's for a set of 4.
"RE7C-L and RE9B-T, two of each."
Old Jul 14, 2010 | 11:17 PM
Tweek's Avatar
RobotsToRobots.com
My friend told me about a different set of NGK's that work just as well, its just a different model from the OEM, i bought them 7$ each.
BR7EIK and BR8EIK im pretty sure was the types. i have them on now, runs perfectly.
Old Jul 18, 2010 | 11:54 PM
oric4000's Avatar
Which ones are rear and which ones are front spark plugs? I am going to switch them myself, so just to make sure.. Thanks!
Old Jul 19, 2010 | 12:04 AM
Oooh, shiny!
"L" for Leading, "T" for Trailing. Pull one spark plug at a time, and match it up with a new one; it's pretty obvious looking at the heads of the plugs.
Old Jul 19, 2010 | 12:20 AM
alnielsen's Avatar
There are many reasons for poor gas mileage. The ignition system is but one of them. I have had several engines replaced and the mileage has mostly remained the same with all of them, with the exception of the last one. It has gone up slightly. The abilities of the Renesis to get good mileage, as far as I can tell (after 6yrs of ownership and being a constant reader here), remains a mystery. One person gets 150 mi to the tank. The next gets 270.
I'm currently getting 200.
Old Jul 19, 2010 | 03:57 PM
xexok's Avatar
I also get right around 200 a tank driving around the city. Took a trip to denver last week though and highway I managed to get between 20 and 22 mpg, so not to shabby.
Old Jul 20, 2010 | 04:16 PM
813dannykoofey's Avatar
when i first got my car i drove to miami from tampa and i put a full tank and it was a 4 hr drive all highway miles going about 75mph the whole way.
i got back with about a quarter.i guess its not soo bad
Old Jul 20, 2010 | 07:45 PM
SpencerM1's Avatar
Recreational User
See my sig...
All city driving during the week...
Old Jul 20, 2010 | 07:51 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^.....yeah, the debate or guessing will continue. I pretty consistantly get between 220-240 miles per tank(light coming on), that's in sort of a small beach town area, but with some lengthy lights.
To the OP, since this is your first attempt. Get the right plugs and as was suggested, do one plug at a time. There are plenty of DIY's to show you the process.
Someone just posted in that thread, so I didn't have to search for it!
Here it is:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-spark-plug-change-31872/
Old Jul 21, 2010 | 04:36 PM
i heard the fuel pump on the 8's get bad quick if you let it go under a quarter all the timee..
truee???
Old Jul 21, 2010 | 04:42 PM
RIWWP's Avatar
False.
The fuel pump on the 8s go bad regardless of fuel level. Granted, most 8s won't need a fuel pump replacement till 120k+, but if you are a very hard driver, you can start running into issues as soon as 60,000. By 60,000 though, most 8 pumps are starting their decline, though you may not notice for double that.
Now, if you run it out of fuel, or low enough with enough high G corners under load and cause pickup problems, then yeah, you can easily have pump issues faster, as the fuel is a lubricant to the pump.
You will have a bigger issue getting a lean spike from sudden no fuel or limited fuel, and if under high revs/high load, this can blow your engine.
Not something to strictly worry about, just I wouldn't recommend going WOT when you are about to run out of fuel. It's not the best way to get to the gas station anyway.
Old Jul 29, 2010 | 05:20 PM
ASH8's Avatar
Super Moderator
Again..this is an S2 Forum...OP
Series 2's have a different Fuel Pump...
I am with Dave, I get consistently 400 - 440 KMS a Tank or 240 - 250 MPG
Old Jul 29, 2010 | 05:22 PM
Oooh, shiny!
Originally Posted by ash8
240 - 250 MPG
Oh my.
Old Jul 29, 2010 | 06:18 PM
jasonrxeight's Avatar
Oh my.
he probably meant miles.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
DVerdeyen
Sep 13, 2015 11:19 AM
GARCIAC951
Sep 10, 2015 07:17 PM
